BIKELAND > FORUMS > ZX-14.com > Thread: Help! 15 K Valve Adjustment - Who do you recommend in the Tampa Area? NEW TOPIC NEW POLL POST REPLY
SPECIAL EDITION ZX-14
HIGHLANDER-THERE CAN BE ONLY 1
posted January 07, 2012 09:16 PM
Hi everyone, Any suggestions for 15 K valve adjustment service in the Tampa Bay area?.
Please recommend some good honest shops with reasonable prices.
WHITE SPECIAL EDITION, TWO BROTHERS EXHAUST, FENDER ELIMINATOR, HELI BARS, FLIES OUT, PC111, QUICKSHIFTER, CUSTOM MAP BY DYNOWORKS OF SARASOTA, WHITE FRAME SLIDERS, Michelen STs GEL POWER GRIPS.
2009 H-D ROAD GLIDE, METALLIC ORANGE PEARL!! SOLD AND BOUGHT A NEW CAMARO
kawa74
posted January 07, 2012 09:42 PM
Smokin 14 just opened up a shop, Docs Cycle Work's . I believe he is in your Area
"I have never met a man so Ignorant that I coun't Learn from him"..."Galileo"
justoyz2
Justoyz Racing
posted January 08, 2012 06:34 AM
I agree, if you are not going to adjust them yourself. There are alot of shops out there they will say they did it; you really won't know if they did it or not, unless the valves are too tight and you have a loss of compression. If your bike is running good, you won't be able to determine if it was done or not..... They will charge you for actually removing the cams and changing out shims... but won't give you the shims they removed.....
2012 zx14R-blue,2012 zx14R-black, 2014 zx14Trbo, 2011 zx10R, 2007 zx10 Turbo.....
Rook
posted January 08, 2012 01:16 PM
I can change oil and adjust a chain, change an air filter, install a PC--normal stuff. No internal engine wrenching until i did the valve adjustment. Long story short----took at least 60 hours to do the work and thoroughly understand the process. I ended up adjusting one too tight and had to go back and redo it.
I would guess that your valves are still in spec at 15K. I only had 1 that really was really a concern at 30K. You could do the valve clearance check and in all likelihood, that would be all you need to do.
Taking out the camshafts, reinstalling and keeping the timing is crucial. Screw that up the motor is toast. I have a lot of pics and even quite a bit of pictorials with text I can give you links to....if you want to do this. I'm actually really close to finishing all the write ups soi that may be all you need----if you have the time and inclination. My bike was out for almost the whole summer and most of the fall. sucked. but I know it was done and I know when to check it again and it will be a lot easier next time.
If you are not really into wrenching, I would suggest letting a trusted shop do the job. YOU tell them you NEED to see the open head and see the clearances checked with a feeler gauge before ANY adjustment is made. No way they can gyp you if they do that ---if the feeler won't slide right through, it is out of spec. Tell them you also want to see the same process after the adjustment (if it needs it). The blade should slide right through or the valve clearance is not adjusted. They might think you are a PITA but if you throw in a few extra $$$ be worth your peace of mind IMO.
Rook
posted January 08, 2012 01:20 PM
BTW, SEZX-14, big highlander fan here, too.
"The Game, it's what we do." : )
posted January 08, 2012 03:23 PM        Edited By: smokinZX14 on 9 Jan 2012 00:12
We can do it for you ..I should say i can do it for you at the new shop ....Call Ryan at Docs Cycle Worx 727 776 0575 .. The cost is not that bad to check them , but it gets costly if they need adjustments ( reshiming ) because the cams have to come out .. Figure in a new valve cover gasket .. It crazy not to change it while it's all apart ..
Tell Ryan that Lee to told you to call ..
Rook
posted January 08, 2012 04:43 PM
+1, definitely change. Mine leaked before the adjustment and still leaks after torqueing---even put the washers in there under the bolts. Next time I will just go ahead and replace the gasket and the rubber ring-os on top of the cover. ~$4 for all six. change 'em IMHO.
The gasket and the ring-os are an updated part. if your bike is 2006-08, you have the older ones that tend to allow head cover leak eventually.
KAWITOM
My 12R gone but not forgotten
posted January 08, 2012 05:33 PM
unless you have alot of patience this is a task I wouldn't recommend someone doing for the first time, there isn't a whole lot of room to work in there, at our dealership none of the other techs even want to do a valve adjustment on a 12r or 14's they ask me to do them. Because for them they are at flat rate, hard to make time on I get payed hourly because it's only a part time gig for the parts discount. After you have done it once you know what to expect not impossible just be patient
2012 ZX-14R SE
2002 VULCAN MEAN STREAK (11.41 @ 114 best 1/4)
I BLEED GREEN
posted January 09, 2012 09:10 AM
thanks for the replies, I don't have the tools or expertise so I need to rely on others. Rook's reply certainly proves that.
posted January 10, 2012 06:28 AM
Get Lee to do it Tom.
posted January 10, 2012 11:34 AM
Thanks Dave; I was hoping you'd chime in. Have you done your 15K yet?
0.33667278289795 seconds processing time
