BIKELAND > FORUMS > ZX-14.com > Thread: 1.75 correction factor,,, NEW TOPIC NEW POLL POST REPLY
redbarron2006
posted January 06, 2012 11:09 AM
Fresh of dyno. New amsoil in the belly, bike made 196.2 at 10, 000... 115 tq.
Same dyno 3 years ago showed 174 on my 2006... Take in for the good weather and what I call dyno-I-tes and this Thing is still a good 20hp over the old bike that had a pc3 and flys out.
redbarron2006
posted January 06, 2012 12:35 PM
http://i285.photobucket.com/albums/ll63/redbarron07/dynosheet2012.jpg
Wheelie
Old Man
posted January 06, 2012 12:36 PM
wee
redbarron2006
posted January 06, 2012 01:02 PM
seems a bit optimistic but it runs its ass off..
Grinner
posted January 07, 2012 01:53 AM
+1 bit optomistic too. and 11200 rpm in 5th gear does not correlate to 145mph , seems to me it would be probably 4th gear which will give more horsepower and torq?
Does anyone agree?
Seno
BANNED FOR LIFE!
posted January 07, 2012 04:43 AM
RPM & MPH do not correspond unless he has like -1/+5.... 2900 RPM 1.4 TQ, BUT 3000 RPM 55 TQ???
Something is off.
posted January 07, 2012 04:49 AM
Seno, look at hp at 2,900 rpms. Obviously that's where he started the run.
biggmoinc
posted January 07, 2012 05:13 AM
Quick question, as far as racing shift points do u think that shifting at 10500 is going to b better than 11k or so?
biggmo@aol.com
redbarron2006
posted January 07, 2012 07:16 AM
the runs were done in 4rth gear
Lacker 14
posted January 07, 2012 08:56 AM
so is that 174 hp on your 06 with stock pipes? my 06 and 08 did 177hp with a full brock system.
joseph702
posted January 07, 2012 10:03 AM
that dyno looks very messed up in impo . afr speed and every thing looks off
justoyz2
Justoyz Racing
posted January 07, 2012 10:06 AM
Unless I am looking at this wrong, starting at 2900 to 7600 rpm; the dyno shows the bike is very lean 15. to 1 @ 2900 to 14 to 1 with alot of 16's, 17s and even some 18 to 1 ratios.
What exhaust is installed on your bike, 2ndly why does yours go way rich like 12s after 9700 rpm.... it's in the 12.7 to 1 and gets richer..... the power really falls off quickly... this is unlike the other 14r's
Can you explain?
2012 zx14R-blue,2012 zx14R-black, 2014 zx14Trbo, 2011 zx10R, 2007 zx10 Turbo.....
redbarron2006
posted January 07, 2012 10:40 AM
this bike is DEAD STOCK... and 12s is NOT way rich..
kawa74
posted January 07, 2012 10:49 AM
Look at top of Chart. ..STANDARD , not SAE. SAE is about 97% of 196 standard = 190 , - 1 for oil= 189 , like all the other STOCK piped post.
A/F reading is all messed up.
Rickey G's was 195 STOCK piped @ STANDARD x 97% = 189.15
Were did I get 97%?? Smoking dyno post , with a SMEG pipe = 202.8 STD; SAE pull was 197, divided by 202.8 = 97%
"I have never met a man so Ignorant that I coun't Learn from him"..."Galileo"
joseph702
posted January 07, 2012 12:27 PM
very nice kawa. some very smart people on here. and for the afr on stock pipe like that its scary . im 13.0-13.2 thru almost the whole thing with brocks ct.
posted January 07, 2012 12:40 PM
I have always been told that shifting higher is better. I have not run any faster shifting at a higher rpm. I shift at 10,500 now
redbarron2006
posted January 07, 2012 12:55 PM
you have to realize, i could only get the reader about halfway down the stock muffler. i dont know if this effected the reading or not. regardless, 190+ for stock bike..i am satisfied..
joseph702
posted January 07, 2012 01:03 PM
190 hp stock bike is sick im pushing 190 with head cut and super sport and brocks pipe. so 190 is amazing . and ya 10,500 was a great shift point for me too
kaw now
posted January 07, 2012 07:57 PM
Looks lean on account of pair valve maybe. And catalyc converter.
justoyz2
Justoyz Racing
posted January 08, 2012 06:46 AM
I am not saying your numbers are not good, just curious as to why the bike is pulling such lean numbers. As to the a/f richer than 12.7 to 1; those are very rich numbers for a stock bike. I know the Gen 1 w/stock exhaust was very rich as well; at least the 14R doesn't go so RICH. I can't wait to get mine.
posted January 08, 2012 06:49 AM
We had a hard time getting the sniffer into the stock pipe, so I didn't even bother. I think he posted that they could not get the sniffer fully into the pipe, and that will account for odd readings from the sensor.
justoyz2
Justoyz Racing
posted January 08, 2012 07:02 AM
yeah, I read that, but it's not like you need the entire copper tube in the exhaust. On my turbo bike, only about 4 inches was installed.
posted January 08, 2012 12:10 PM        Edited By: Shane661 on 8 Jan 2012 20:12
I have had very inconsistent results without a proper sensor arrangement. Reversion is a big issue, and I have seen this on MANY bikes. On your turbo, if it was at at the dump pipe, that is an entirely different animal....
I can promise you, his a/f results are most likely from the sensing tube arrangement. The power output is entirely normal.
redbarron2006
posted January 08, 2012 08:31 PM
Since I was not actually tuning, I was not overly concerned about the wideband working or not. After reading what Wheelie and them are doin I am pretty sure the big HP this motor is Making is undeniable.
0.37967109680176 seconds processing time
