BIKELAND > FORUMS > ZX-14.com > Thread: TRE for the ZX14R NEW TOPIC NEW POLL POST REPLY
posted December 25, 2011 01:36 PM
TRE for the ZX14R
I looked on my zx14r and the plug for the TRE are the same .. Wiring is the same as the Gen 1 , color codes are the same ... This should open the flies faster and not upset the T/C system.... This maybe a better idea than pulling the flies because you can still use the TC .. Pulling the flies may cause the TC not to work right ...
Note i have not tried this yet !! Wee has his flies out and i believe he has not tested the TC to see if it still works as factory ..
I emailed brock with this info , i asked if he could test this on the new ZX14R .. So we may have some info soon on what works and what doesn't .. Or what works best ..
Wheelie
Old Man
posted December 25, 2011 01:40 PM
TC works with the secondaries out.
wee
kaw-rick
posted December 25, 2011 01:42 PM
i have a tre if any1 needs it.
posted December 25, 2011 01:45 PM
wee
Good News Wee .. Thanks for the info .. The TC must work with spark and timing then and not the flies ..
Wheelie
Old Man
posted December 25, 2011 01:47 PM
wee
yes, it sputters with wheel spin when tc is on.
wee
KAWITOM
My 12R gone but not forgotten
posted December 25, 2011 01:50 PM
That would explain why mine was stopping at 10,000 when I had no signal from the rear wheel sensor.
2012 ZX-14R SE
2002 VULCAN MEAN STREAK (11.41 @ 114 best 1/4)
I BLEED GREEN
posted December 25, 2011 01:57 PM
Now we just need to come up with a way to get rid of the 186 limiter ... I'm thinking it will take two new wheel sensors ( front and rear) with less holes ..Or a reflash of the ECU ..
Seno
BANNED FOR LIFE!
posted December 25, 2011 04:09 PM
Very good news indeed. Not trying ot hijack the thread Smokin, but did you notice any performance increase Wee?
chriszx14R
posted December 25, 2011 04:14 PM
I really think that if someone could get an extra set of rotors and machine out every other slot the bike would think it is going half as fast as it is. If i get the parts and do the machining who would be willing to try it?
2002 ZX12R
2004 ZX10R
2012 ZX14R
cas15
posted December 25, 2011 04:27 PM
smokin does the bike perform better at the track when you get rid of the limiter or is that just for speed
  Ignore this member    Click here to visit cas15's homepage.
87gtNOS
posted December 25, 2011 04:34 PM
To make our snowmobile speedometers read lower (and more accurately) we grind one or two teeth off the speed sensor pickup wheel. It's a 'star' wheel type thing that is about 3/4" in diameter with about 12 teeth or so and the pickup senses them. (looks like a little gear)
I have not seen the new ZX14 sensor and what it sees, but you could start with grinding off a tooth, or opening up a 'window', hence making it have one 'window' less.
Hope this helps spark some ideas!!!
01 ZX12R
BobC
posted December 26, 2011 01:46 AM
I just wrote this in the other thread:
Reflashing appears to be the easier option. I was wondering though, since the speedo works on a dyno when the front wheel is stationary and no error codes appear, would disconnecting the front wheel-speed sensor and "speedo healing" the rear sensor signal be successful? You may have to switch off TC every time the bike is started, as it defaults to "on" but it's worth a try.
No bikes here yet so I can't try it myself.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
posted December 26, 2011 05:28 AM        Edited By: Shane661 on 26 Dec 2011 13:30
Error codes do appear when on the dyno, after the bike is ridden stationary for a bit.
kingtramp
posted December 26, 2011 07:32 AM
This will sound crazy as hell, however the wheel sensor is looking for multi slot count (windows if you will )to determine wheel speed. Why not try some 200 mph duct tape and shut the windows?? This coud easily reduce signal count coming from brake rotor that is going to the sensor and result in lower wheel speed being noted by ECU. Like I said crazy as hell.
BobC
posted December 26, 2011 11:04 AM
I think it wouldn't work because the pick-up is inductive not optical.
Stock wheelbase
justoyz2
Justoyz Racing
posted December 26, 2011 11:24 AM
All info learned from my 2011 zx10R
-2ndaries removed... no issues w/TC
-top speed limiter removed by DP Tunes or Ghuls
-added ignition timing addes by DP Tunes
-2ndaries replaced and open faster by DP Tunes
-TC no issues, but you must turn it off prior to drag racing, or running on the DYNO
2012 zx14R-blue,2012 zx14R-black, 2014 zx14Trbo, 2011 zx10R, 2007 zx10 Turbo.....
87gtNOS
posted December 27, 2011 04:26 PM
He will need to grind off one window, making it have one 'longer' window. The sensor is simply counting windows and the less windows, the slower the ECU will think you are going!!!
This will work.
01 ZX12R
0.25720882415771 seconds processing time
