BIKELAND > FORUMS > ZX-14.com > Thread: Help! NEW TOPIC NEW POLL POST REPLY
bykw2
posted December 16, 2011 09:52 PM
Help!
My ZX-14 has not been started for over a month, I tried starting it today and all it does is just turn over without starting, I have gas in the tank. A couple time it act like it wanted to start, but never did.
Does anyone have any idea I can try, before I am faced to bring it to the shop. Please help!!!
justoyz2
Justoyz Racing
posted December 17, 2011 02:25 AM
install a new set of plugs
2012 zx14R-blue,2012 zx14R-black, 2014 zx14Trbo, 2011 zx10R, 2007 zx10 Turbo.....
bykw2
posted December 17, 2011 06:02 AM
Thanks I will try that.
tnt
posted December 17, 2011 07:43 AM
Check your battery voltage, make sure it os really putting out on all six cells, charge iy up to 13.??? , then it will fire off with the new plugs! Probably need fresh fuel too! The fuel we get now can go bad real quick! !!
Quarter Pounder
with Cheese
posted December 17, 2011 10:42 AM
prolly just low battery voltage. Not uncommon for mine to sit up for a month at a time, and it starts no problem.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
kawpower
Mr kawasaki 2 you!
posted December 17, 2011 03:11 PM
next time buy a battery tender and keep it plugged in, my original 06, batt lasted 5yrs.
bykw2
posted December 17, 2011 06:49 PM
Thanks for all the suggestions changing the spark plugs did the trick, One thing I discovered was the guy who worked on my bike last replaced the plugs with some NGK CR9E instead of the NGK CR9EIA-9 which the bike came with. The plugs that were remove were totally black on the ends, I assume this is heavy carbon. I added a little fuel injector cleaner, to help with that old gas in the tank. On tomorrow I will add some fresh gas and a little more fuel injector cleaner, the bike run well now.
Thanks again for all the help..
bykw2
posted December 17, 2011 06:54 PM
0.24280381202698 seconds processing time
