BIKELAND > FORUMS > ZX-14.com > Thread: Putting on arm 2012 14r NEW TOPIC NEW POLL POST REPLY
KAWITOM
My 12R gone but not forgotten
posted November 29, 2011 04:14 AM
The one thing that I noticed that is going to be a little of a challenge is,I hope there is enough slack in the traction control sensor wire for an extended arm and in my case I can't use the brake arm piece for my adam's arm I am going to use the oem brake hanger and weld a threaded button on the arm to do heim joint setup to hold brake hanger in place. Looks like aftermarket swingarms are gonna get more expensive, because of the traction control sensor! The green is little different than my zx12's green it is a little darker and has more metallic in the paint. I will post some pictures later, hoping for a at least fifty something degree day to go for a ride otherwise straight into the mods already found where my five button progressive is going, who needs a tool holder anyway LOL
2012 ZX-14R SE
2002 VULCAN MEAN STREAK (11.41 @ 114 best 1/4)
I BLEED GREEN
1badzx14
08 Turbo zx14!!!
posted November 29, 2011 09:01 AM
Can't you just extend the wires?
Seno
BANNED FOR LIFE!
posted November 29, 2011 10:26 AM
Same sprockets from previous years?
dakota9498
posted November 29, 2011 11:27 AM
Wheelie confirmed it is the same.
2008 ZX14
KAWITOM
posted November 29, 2011 01:03 PM
Yea gonna pull out the soldering gun, guess I gotta get over the it's new thing and just get in there and get busy. LOL Putting the swingarm on this weekend and my tiger tail should be here this week, gonna start placing nitrous pieces, this bike defiantely doesn't have the spare room my 12 had. I will take pictures and post them, don't know how much help they will be seeing as the back end is no different, suppose it can't hurt and if someone sees something that could be done better, I'm sure they would say something and that's a good thing.
Been around bikes along time, but this if the first time getting serious with a fourteen thankfully I know there is a lot of knowledge available with you guys later
2012 ZX-14R SE
I BLEED GREEN
Wheelie
Old Man
posted November 30, 2011 03:48 AM
I confirmed the rear, not sure about the front.
wee
KAWITOM
posted November 30, 2011 04:57 AM        Edited By: KAWITOM on 30 Nov 2011 13:00
here is one picture Here she is sitting at 67 1/2" without the front lowered or strapped, I am waiting for the tiger tail, then I will see what I can get away with without bottoming out.
2012 ZX-14R SE
I BLEED GREEN
KAWITOM
posted November 30, 2011 05:03 AM        Edited By: KAWITOM on 30 Nov 2011 13:08
see this is what I was talking about I am going to my buddies business and see if he can laser cut me a new designed piece will have to make the part that rests on the swingarm longer so we can cut holes for the sensor and the piece will still be strong. The wire is long enough I just flipped it around going with a 24" brake line picking that up today. The suspension geometry must be different because the dog bones that I bought came off a gen 1 and when I left them where he had them set they were way off. I am going to have adam's make longer threaded adjusters to go lower.
2012 ZX-14R SE
I BLEED GREEN
KAWITOM
posted November 30, 2011 06:16 AM
I retract what i said about the threaded adjusters, forgot that previous owner of these had a straight bar link on his gen 1 and I think he cut these adjusters down, so if anybody buys adam's adjustable links they should work fine as long as the person didn't use straight links sorry for any confusion. Tom
2012 ZX-14R SE
I BLEED GREEN
blackbullet76
posted November 30, 2011 07:42 AM
If the harness plugs in somewhere, looks like you could make an extension harness. What would happen in it was left unmounted and just ziptie it up somewhere? Figure it would give an error code, but would it effect how the bike ran?
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
posted November 30, 2011 07:48 AM
Call Doug at spencer cycles and get his super slammers lowering links .. They are much much longer than the Adams links ..
KAWITOM
posted November 30, 2011 08:30 AM        Edited By: KAWITOM on 30 Nov 2011 16:32
I should have a new piece hopefully this afternoon that will have a cutout for the sensor, but I think you could run with the sensor but there would be a annoying flashing something on the display, picking up new lines and vortex sprocket today. Wheelie since I can't run mine up here I'll send it down and you and JZX can race each other LOL
2012 ZX-14R SE
I BLEED GREEN
Lucky14
posted November 30, 2011 03:02 PM
I called McIntosh today and talked with Terry.
His arm uses the stock brake hanger so there is no issue with the TC sensor.
Wheelie
Old Man
posted November 30, 2011 03:23 PM
that's good to hear.
wee
posted November 30, 2011 03:26 PM        Edited By: smokinZX14 on 30 Nov 2011 23:29
True .. Terry uses a brake rod that bolts to the caliper and lower part of the swing arm ..
Bently
2012 14r In Blue and no Mods!
posted November 30, 2011 03:39 PM
Same as my evil arm
KAWITOM
posted November 30, 2011 04:13 PM        Edited By: KAWITOM on 1 Dec 2011 00:15
Got a little more done today, messed up my measurement on brake about an 1 1/2" too short, luckly I think it will work up front. I have a new brake hanger piece being made should be ready for the early next week.
2012 ZX-14R SE
I BLEED GREEN
KAWITOM
posted November 30, 2011 04:18 PM
Anyone have any good ideas for solenoids other than in the battery box?
2012 ZX-14R SE
I BLEED GREEN
KAWITOM
posted November 30, 2011 04:21 PM
Got a little bored since I can't ride, LOL hopefully no one get offended!
2012 ZX-14R SE
I BLEED GREEN
posted November 30, 2011 04:34 PM
its about time to update your tag!
KAWITOM
posted November 30, 2011 04:39 PM
That was an old one off my zx12 when me and buddies were messing with each other, his busa plate said HA ZX12 so I had to respond, couldn't let it slide LOL
2012 ZX-14R SE
I BLEED GREEN
Bently
posted November 30, 2011 08:04 PM
Looks great Tom, Can't wait until I get a chance to throw a leg over it and see how fast I can go!
Superman T
posted December 01, 2011 08:01 AM
KAWITOM-- Do you have a spray bar and nos spraying into the throttle bodies or are you fogging through the air filter?
KAWITOM
posted December 01, 2011 02:19 PM
I am using a spray bar for the progressive and fogging the second stage, gonna set up the power commander to switch to nitrous map when spray is activated, second is just an oh shit button
2012 ZX-14R SE
I BLEED GREEN
bradkong12
posted December 01, 2011 02:58 PM
NICE!!! she looks even sexier with a arm, still hate those gonzilla exhaust
CONGRADS!!!!!! SHES BEAUTIFUL
bradkong12
0.32048606872559 seconds processing time
