BIKELAND > FORUMS > ZX-14.com > Thread: Nos gearing NEW TOPIC NEW POLL POST REPLY
06redzx14
posted November 21, 2011 06:10 PM
Nos gearing
What would be a good gear combo for a 68" 270hp zx14? Rider is 240 suited engine driven lockup
Bently
2012 14r In Blue and no Mods!
posted November 21, 2011 06:12 PM
My vote would go for 16-45 or 46
RICH CRAFT 1
posted November 21, 2011 06:35 PM
17-45
Red 06 ZX14 RR
Bently
posted November 21, 2011 06:57 PM
With gearing you need to figure it out yourself because you will get 10 replys and 10 different answers.
06redzx14
posted November 21, 2011 07:02 PM
true, i've tried 17/44 and 17/42, but i just need a little more push off the line
killer 14
posted November 21, 2011 07:05 PM
drop down to 16t that should help
Bently
posted November 21, 2011 07:06 PM
I run the 16-45 and spray in first gear.
06redzx14
posted November 21, 2011 07:22 PM
yea i've been experimenting with 2 stages of nos. first stage is only 20 hp on at full throttle
quick6
posted November 21, 2011 09:48 PM
i run 16-46 on motor, and 16-44 on a 50 shot. the 45 on the rear on the gas was too tight for me at the line.
2006 zx14, fully dressed and sliding(Charlie Sheen)
quikgix
posted November 22, 2011 06:31 AM
I was running 16-43 and I ran out of gear at the stripe in sixth gear at 166mph, so I changed the rear out with a 42 and touched the speed limiter at 170 at the stripe. So now Im going to grind 2 nubbs off on the speed sensor trigger.
1352cc 8.39@159mph on motor cant wait to spray this bitch
LeonidasZX14
posted November 22, 2011 10:23 AM
are you sure you weren't in 5th gear? 16/43 should not run out of gear. Weren't you like 160lbs? I ran 16/41 and went through in 5th at 170 on before.
09' ZX14
quikgix
posted November 22, 2011 05:57 PM        Edited By: quikgix on 23 Nov 2011 02:00
this pass was with 16-43 gear and I didnt get on the nitrous till i was well in to second gear. when I finally was able to come out the hole on the spray it ran all the way out through sixth gear.
0.23301410675049 seconds processing time
