BIKELAND > FORUMS > ZX-14.com > Thread: i need expert help. turbo zx14 trex NEW TOPIC NEW POLL POST REPLY
vettez062002
posted November 13, 2011 07:06 PM
Ok guys. I'll make this short and simple
My turbo trex blew the motor bad last year
It's been sitting for 6 months. I picked up a factory longblock with 1900 miles.
Here is what I want...
To use my Mr turbo turbo kit and be able to have a streetable trex again. My last build was so over the top and so expensive
Is it possible to turbo a stock motor without blowing it Tue hell up? I made 300whp and it wad waaaaaaaaay to much. I want like 230-240 tops. I miss ripping my trex around corners like irs meant for
Can I just remove the butterflies and get it tuned?
2007 Turbo T-rex
Oz Booster
posted November 13, 2011 09:29 PM
What caused the problem with the last one ??
low boost on std motor should be no prob,
just be sure its tunned good ,
maybe even go with e85 if its readily available near you
vettez062002
posted November 14, 2011 06:01 AM
looks like #4 rod pushed throught the case from to much boost and it was not finished being tuned yet. I was not drivng it when it blew up
am I ok with the stock head bols and head gasket ect? ive heard I will need to aleast to headstuds, mechanical timing tensioner?
2007 Turbo T-rex
1badzx14
08 Turbo zx14!!!
posted November 14, 2011 08:04 AM
call chris jones! 1(904)490-8068
Oz Booster
posted November 14, 2011 12:30 PM
Bearing and bottom of rod all black
are the others showing signs of heat too ??
You need an accurate diagnosis of what caused the problem last time and do something about it or you are likely to repeat the damage
Any specific turbo parts in the original ,motor ?? valve springs, studs etc
vettez062002
posted November 14, 2011 12:35 PM
Je pistons. Crowler rods. Arp head studs. Rc750 injectors. Walboro pump. R@d trans. I haven't even pulled the blown motor apart. It's still sitting under the shelves. I assume just to Mich boost and being untuned.
2007 Turbo T-rex
kawpower
Mr kawasaki 2 you!
posted November 14, 2011 02:44 PM
911 chris jones,thanx again 1bad!
kawpower
Mr kawasaki 2 you!
sounds like u have an hpc setup.
vettez062002
posted November 14, 2011 02:49 PM        Edited By: vettez062002 on 14 Nov 2011 22:50
Are you from hpe? I talked to some guys at Cecil about 2 months ago.
Used to. Previous owner had them do everything I've.been trying to unghetto this thing for some time now.
2007 Turbo T-rex
Romans
posted November 14, 2011 03:52 PM
Curious; How much Boost were you running on pump fuel and what were your AFR #'s under Full boost ?
vettez062002
posted November 14, 2011 03:55 PM
No idea. Again.. I wasn't there. Literally I had just put it together after buying it with a shot trans.
2007 Turbo T-rex
Romans
posted November 14, 2011 04:18 PM
To much info missing to Help any. Sorry.
With the set up you listed above 7lbs would have stayed together with proper tune.
Fuel cut in injectors one and four currently my biggest worry. When tire breaks traction Red Line comes quick. Fuel cut = Lean in cylinders one and four. Not good.
vettez062002
posted November 14, 2011 04:23 PM
Well the wastegate spring was 15psi. I am going to run low boost. 5-7psi tops. I just want to keep it as stock motor as possible.
2007 Turbo T-rex
Romans
posted November 14, 2011 05:27 PM        Edited By: Romans on 15 Nov 2011 01:28
Currently at 7lbs creeping 9. ALL Stock Motor , Pump 94 octane.,,,,, 8500 km & 3 back tires, so Far.
vettez062002
posted November 14, 2011 06:31 PM
That's what I'm looking to Here. I just fired the trex.up now n/a until next year. Just weighing out my options. I want to get all bugs worked out of it n/a then start fresh rebuild the turbo and really put it together mint unlike the throwing.parts at it like the previous owner did.
2007 Turbo T-rex
Romans
posted November 14, 2011 06:53 PM
Let see some pics ?
kawpower
Mr kawasaki 2 you!
posted November 15, 2011 05:12 AM
hell no, i aint from hpc!!!!!!!!!!
vettez062002
posted November 15, 2011 07:09 AM        Edited By: vettez062002 on 15 Nov 2011 15:13
Let see some pics ?
when it was turbod
now its basically back together but n/a until next year
there is a laundry list of parts in this thing besides the motor and turbo kit
Oriant racing low pro oil pan with oil filter relocator. orant racing billit clutch cover.
walboro pump, locking clutch, adj, FPR, return fuel system.
electric exhaust dump, ect ect ect.
2007 Turbo T-rex
posted November 15, 2011 09:16 AM
wild ride i am sure
vettez062002
posted November 15, 2011 09:21 AM
no not HPC... HEP!
http://www.heperformance.com/
2007 Turbo T-rex
Romans
posted November 15, 2011 03:00 PM
Which Turbo did they use in your kit ? Looks Awesome 4 sure.
0.23601484298706 seconds processing time
