BIKELAND > FORUMS > ZX-14.com > Thread: Speed Sensor gone??? Anyone notice??? NEW TOPIC NEW POLL POST REPLY
Lucky14
posted October 22, 2011 01:40 PM
Remember the mod to grind 1 or 2 of the 4 pickup points off of the coutnershaft / speed sender nut to fool the speed limiter?
Check the CS sprocket cover - the speed sensor is either gone or has been moved.
Is this still going to be the cheap and easy mod, or is speed detected from the wheel(s) now?
WARBIRD
posted October 22, 2011 01:51 PM
Good pics Lucky...........probobly the wheel speed sensors..........
I'd Rather Be Roadracing.
Seno
BANNED FOR LIFE!
posted October 22, 2011 03:26 PM
Hmm wonder if we will need to get a different "speedo Healer" for the new one if we start playing with the gearing?
01smokes
posted October 22, 2011 04:51 PM
Gearing changes will not affect MPH if the wheels are recording MPH...
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
1badzx12r
posted October 22, 2011 05:37 PM
GPS suckers
chrisrok
posted October 22, 2011 06:57 PM
The new Zx14 pulls a signal from the rear brake rotor now, that is where the speed sensor pickup is located now.
Lucky14
posted October 22, 2011 07:21 PM
Soooooooooooo, another little thing I don't have to do!
This is looking better and better .....................
zixxer14
Damn that was Quick
posted October 22, 2011 08:14 PM
I don't see an idle adjustment either.
loki 7
posted October 23, 2011 05:45 PM
Looks like the oil drain plug has been relocated as well
Brock
Sponsor
posted October 24, 2011 01:26 PM
Could be a problem for high speed guys... looks like Don Guhl might be getting more work. We still don't know how to trick the high speed limiter on the wheel speed sensed versions of the BMW's. We broke 200 on the standard version without ABS/DTC by grinding the speedo pick-up lug. We sent data logs to BMW and they said "it's not restricted" even after we showed them before and after charts from flat-line, not pulling any more RPM runs of 194 MPH to pulling to red line breaking 200... they still denied a restriction.
Brock
www.BrocksPerformance.com
  Ignore this member    Click here to visit Brock's homepage.
RICH CRAFT 1
posted October 24, 2011 03:32 PM
yes the old bike was an easy fix just grounded one corner off the four corners off the front sprocket bolt made it think it was going 150 at 200. it's okay though just put a big shot on it and you won't need to gear it down LOL.
Ken
Red 06 ZX14 RR
BobC
posted October 25, 2011 05:48 AM        Edited By: BobC on 25 Oct 2011 13:50
If this assumption is correct and the wheel-speed sensor pulse disappears straight into the ECU where it gets used for ABS, Speedo (traction control?) etc it could prove hard to de-restrict the bike.
If that's not the case then some type of speedohealer might still work, after all it's just a box which outputs tach pulses at a different rate to the input.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
GREYHOUNDMOSES
posted October 25, 2011 06:24 AM
The obvious fix for derestricting would be new rotors with a couple fewer slots.
justoyz2
Justoyz Racing
posted October 25, 2011 08:04 AM
Brock could be right, I really didn't look at my 2011 zx10; I am sure there's a way, but I had mine done with the reflash....
I am sure both bikes have the same technology, rotors is not the answer, if you don't install the TC plates, your bike will run wicked.... as in wack
2012 zx14R-blue,2012 zx14R-black, 2014 zx14Trbo, 2011 zx10R, 2007 zx10 Turbo.....
BobC
posted October 25, 2011 01:12 PM
Is there a wiring diagram for the 2012 bike available yet?
Stock wheelbase
Wheelie
Old Man
posted October 25, 2011 01:14 PM
x2
wee
zixxer14
Damn that was Quick
posted October 26, 2011 07:52 PM
Top fuckin' secret!
ryn0cer0s
Rider for Life
posted October 27, 2011 07:12 AM
Since some versions are available with ABS (overseas, from what I hear), then the speed sensors would have to be on the wheels. Not sure about speedohealer, I have one, but it would be a whole redesign. Prob a reflash will be the answer in the end, as soon as someone figures out how.
The oil plug seems to be another mod we dont have to do since it is up front instead of on the bottom (does KHI read this forum? lol).
RYNO
2010 Candy Persimmon Red ZX-14
Brock's Ceramic coated Alien Head full exhaust
PCV, SpeedoHealer, lowered
"Never ride faster than your guardian angel can fly"
Brock
Sponsor
posted October 28, 2011 11:18 AM
Correct, and there would be enough of a market for the 14R to justify the R&D. There is also the problem of extending the sensor wire for extended wheelbase use - "just add some wire" can add enough resistance at the connections alone to cause more problems. The 14 crowd may get a new lesson in high tech hassle very soon.
Brock
BobC
posted October 28, 2011 12:52 PM
Also, with a Speedohealer on bikes up to 2011 it's easy to program a speedo under-read to fool the limiter for top speed events and then program it so the speedo reads correctly for road use. Or to change it when you make a gearing change. It easily suits either purpose.
If you installed rotors with fewer slots, a mechanical solution rather than an electronic one, it would give a fixed offset which you would be stuck with. It's a whole new ball game. I was in touch with Healtech last week and they don't have the solution yet but they are aware of this.
Stock wheelbase
0.32025289535522 seconds processing time
