BIKELAND > FORUMS > ZX-14.com > Thread: Flies out without PCIII ? NEW TOPIC NEW POLL POST REPLY
CraZX14
posted October 18, 2011 04:02 PM
So if I start turning the '06 more back into stock form, would it be an absolute "no-no" to take my PCIII out with the secondary TB plates removed? I'd like to keep my PCIII if I trade bikes but putting those plates back in is something I'd like to avoid. Anybody try this?
2003 L.E. Hayabusa
oldkawboy
posted October 18, 2011 06:23 PM
Years ago my son pulled the flies from his 14 before he bought a PCIII. He took it to a dyno and it showed like 16:1 a/f ratio.
I wouldn't do it.
Dan
Audioboyz
posted October 18, 2011 06:56 PM
I'd want the PCV anyway.When I get rid of my bike the PCV has to stay.First of all my bike is fast with the pipe and 16/43 gearing.I'm going to buy the new 14R and I'll need Brocks new exhaust when he makes it cause my Alienhead has a 2 inch OD and the new bike needs more.The new bike has 42 tooth rear sprocket so I don't think there will be a need for flies removed on the 2012
Craig.
2009 Monster ZX-14
Brocks Alienhead,PCV, flys out,LSL Riser kit,-1 front sprocket,43 Vortex rear sprocket,K&N Air Filter, Zero Gravity tall smoked screen,block off plates,175HP 104 torque
epd345
posted October 18, 2011 06:57 PM
Dan how about the flies out with no PC 3 and the stock exhaust back on. Do I have to reinstall the flys or can they be left out. I have everything saved if I have to put them back in,
badass14r
I'm so bad it hurts!
posted October 19, 2011 03:29 AM
How does it run? If you dragrace I think you shold get a tune. If your just riding on the street and just an occasional flogging you shouldn't be too concerned.
06 black beauty. Flyes out, full brock's alien head, pazzo levers, bmc race filter, double bubble windscreen, frame and swing arm sliders, pc3 with brock's map, ohlins steering stabilizer, mid range velocity stacks, vortex sprockets, 520zzz chain. Ivan's flyes out tre, muzzy advancer +4 degrees.
dakota9498
posted October 19, 2011 04:16 AM
If you were flogging it on the strip you probably wouldn't be concerned because the lean spot is below the normal RPM range used on the strip. The street is where you should be really concerned because it is in that range. But like oldkawboy said, I wouldn't recommend it, that A/F ratio is scary.
2008 ZX14
CraZX14
posted October 19, 2011 06:18 AM
I agree, Dakota. And I also think Oldkawboy makes a good point, but isn't that A/F ratio being scary dependent on where that 16:1 would show up? In other words, I'd imagine the A/F ratio to be dynamic and would therefore vary throughout the powerband and load that the engine is under. But if he is saying that the bike never saw anything richer than 16:1, then I'd think that would definitely be an issue waiting to happen.
2003 L.E. Hayabusa
dakota9498
posted October 19, 2011 06:43 AM
If I remember correctly there is a spike around 3k-4k rpm where it is really lean. I know people that have ran it that way and they have been fine just being conscious of that rpm range. However, I know I wouldn't feel comfortable selling it to someone like that.
2008 ZX14
CraZX14
posted October 19, 2011 07:03 AM
Good advice and much appreciated - thanks!
2003 L.E. Hayabusa
0.23410296440125 seconds processing time
