BIKELAND > FORUMS > ZX-14.com > Thread: 2012 ZX14R Has been Released!!! NEW TOPIC NEW POLL POST REPLY
ZX14Ryan
posted October 10, 2011 04:32 AM
The moment we have all been waiting for.....pictures, specs, video....yeehawww this is like x-mas!
http://m.kawasaki.com/ninja14r/Gallery_videos.aspx
Just another Broke Ass trying to go Fast
1badzx12r
posted October 10, 2011 04:35 AM
ZX14Ryan
posted October 10, 2011 04:37 AM
2012 Ninja® ZX™-14R $14,699 MSRP
ZX14Ryan
posted October 10, 2011 04:38 AM
Engine Four-stroke, liquid-cooled, DOHC, four valve per cylinder, inline-four
Displacement 1,441 cc
Bore x Stroke 84.0 x 65.0 mm
Compression Ratio 12.3:1
Fuel System DFI® with four 44mm Mikuni throttle bodies
Ignition TCBI with Digital Advance
Transmission Six-Speed
Final Drive X-Ring Chain
Rake/Trail 23 degrees / 3.7 in.
Front Tire Size 120/70 ZR17
Rear Tire Size 190/50 ZR17
Wheelbase 58.3 in.
Front Suspension /wheel travel 43mm inverted cartridge fork with adjustable preload, 18-way compression and 15-way rebound damping adjustment / 4.6 in.
Rear Suspension /wheel travel Bottom-link Uni-Trak® and gas-charged shock with adjustable preload, stepless rebound and compression damping adjustments, adjustable ride height / 4.9 in.
Front Brakes Dual semi-floating 310 mm petal discs with dual radial-mounted four-piston calipers
Rear Brakes Single 250mm petal disc with twin-piston caliper
Overall length 85.4 in.
Overall width 30.3 in.
Overall height 46.1 in.
Ground clearance 4.9 in.
Seat Height 31.5 in.
Curb Weight 584.3 lbs.
Fuel Capacity 5.8 gal
Color Metallic Spark Black, Candy Surf Blue, Golden Blazed Green with special graphics (SE)
Warranty 12 months
Good Times™ Protection Plan 12, 24, 36 or 48 months
2012 Ninja® ZX™-14R $14,699 MSRP Home Motorcycle Supersport
*Note: Specifications and pricing are subject to change.
1badzx12r
posted October 10, 2011 04:42 AM        Edited By: 1badzx12r on 10 Oct 2011 12:52
good luck kawasaki..
The new ZX-14R is also equipped with a slipper clutch and a KTRC traction control and ignition system, which help to account for its new price tag of $14,699.
Curb Weight: 584.3 lbs.
codyc_13
posted October 10, 2011 05:05 AM
all i can find is the mobile version, there has to be a desktop version somewhere
8.97 at 149mph
posted October 10, 2011 05:07 AM
All fotos etc on frontpage if this site as well as in this forum
1badzx12r
posted October 10, 2011 05:21 AM        Edited By: 1badzx12r on 10 Oct 2011 13:25
http://www.youtube.com/watch?v=44xCj9RArhQ
at the end of the video 9.78 ..6 years ago in vegas with rickey coaching
06redzx14
posted October 10, 2011 05:23 AM
Don't think I like the slipper clutch. Hope the crank fits
dakota9498
posted October 10, 2011 05:25 AM
I wonder how much the slipper clutch hurt the launch?
Plus this motorcycle is seriously porky. I want this motor in my bike, that weighs between 475 and 480 wet.
2008 ZX14
thutch26
thutch26
posted October 10, 2011 05:30 AM
Why did the other thread get deleted? Wtf? Lots of good discussion on there about it
dogg24
posted October 10, 2011 05:32 AM
It's back now!
2012 ZX14R SE, Streetmeg, PCV
kawasakijockey
posted October 10, 2011 05:54 AM
Dont think so. It has larger journals.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
frEEk
posted October 10, 2011 05:57 AM
Closing thread. Want to try to keep the discussion from getting fractured across several threads.
Continue in http://www.bikeland.org/board/viewthread.php?FID=27&TID=63965
0.21745586395264 seconds processing time
