BIKELAND > FORUMS > ZX-14.com > Thread: E85 question NEW TOPIC NEW POLL POST REPLY
JZX
posted September 15, 2011 02:57 PM
E85 question
I remember reading the e85 thread, instead of digging it back up I figure I would just come out and ask.
I have a map in my bike now with the super sport head, af is at 13.0-13.2 avg. Using my PC3 w USB hub, what do I need to add and where to run e85 at the track? I remember reading 35-40% more across the whole curve. Can I get clarification on this?
06 ZX14 65"
Best 1/8 mile 5.68@126.4 on a 1.41 60'
Best 1/4 mile 8.87@152.7 on a 1.47 60'
01smokes
posted September 15, 2011 03:28 PM
ya about 30% is your bike a 06-07 or the 08-11??
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
JZX
posted September 15, 2011 03:35 PM
06 model
06 ZX14 65"
JZX
posted September 15, 2011 04:11 PM
Im hittin the track tomorrow night so I am wanting to run e85 since they sell it everywhere around here.
06 ZX14 65"
wrongway
posted September 15, 2011 05:20 PM
35% over pump gas .... might be less with some of the race fuels that need a fat map.
wrongway
posted September 15, 2011 05:22 PM
injectors may be maxed out on the top end .....
Wheelie
Old Man
posted September 15, 2011 05:47 PM
yep, I couldn't run e85 in my 09,
wee
1badzx12r
posted September 15, 2011 07:12 PM        Edited By: 1badzx12r on 16 Sep 2011 03:12
nice paying ET race at temple sunday ..1/8th mile winner 1250.00.. i'm going.. http://www.littleriverdragway.net/
JZX
posted September 15, 2011 08:33 PM        Edited By: JZX on 16 Sep 2011 05:35
we had to pull fuel with the degreed cams and super sport head so how would i be maxed adding 35%? I thought 06 had injectors to handle E85? Thanks though, will try it.
06 ZX14 65"
JZX
posted September 15, 2011 09:40 PM
Maybe if she holds together
06 ZX14 65"
justoyz2
Justoyz Racing
posted September 16, 2011 01:24 AM
When using E85, the amount enrichment will be determined by your compression. I have used it before and tipically I went around 30 to 35%, but I run my bike at 12.8 to 1 a/f. My new 10 needed about 35% in some areas and as much as 40% in others to maintain my desired a/f.
2012 zx14R-blue,2012 zx14R-black, 2014 zx14Trbo, 2011 zx10R, 2007 zx10 Turbo.....
wrongway
posted September 16, 2011 05:32 AM
the 440 cc injectors with a stock pump/pressure with E85 are maxed out around 200 hp ....
you will not be able to add nitrous without going to larger injectors or higher pressure.
hope that helps..
Roy
JZX
posted September 16, 2011 05:57 AM
Thanks Roy, this bike is all motor. I was just making sure I had enough injector to handle an SS head on E85.
06 ZX14 65"
1badzx12r
posted September 16, 2011 06:53 AM
you can always bump up the fuel pressure of the stock pump.. a cheap fix to getting more fuel ..
kingtramp
posted September 16, 2011 08:51 AM
I am trying E85 now. I set my Bazzaz map about 35% rich at idle (1400-1600 rpm) zero precent throttle
I set about 30% rich at launch rpm(6000-7000) 10 to 15% throttle
I set 35% to 25 % rich at WOT (7500 -11000 rpm) 100 % throttle
Use 35% rich at 100% throttle from 7500 - 9500 rpm( reason Highest TQ reached in this zone, engine is breathing more efficently therefore more fuel needed.
Use 25% rich at 100% throttle from 9750 - 11000( reason TQ is now starting to diminish due engine breathing less efficent less fuel is needed.You can carefully increase fuel pressure by removing stock fuel pressure regulator and very carefully crush regulator on spring side .060" this will increase fuel pressure approimately to 50 to 52 psi.
The 06 injector should be good for 210 to 220 hp providing fuel pressure increase.
JZX
posted September 16, 2011 02:31 PM
Just my luck, bike is ready to go-BUT.... after no rain for months, there is a line of thunderstorms practically on top of us...
06 ZX14 65"
0.23821902275085 seconds processing time
