motomoto
posted August 19, 2011 04:58 PM
?'s about stretching
I am supposed to pic up a stock 2007 tommorow and would like to order a swing arm extention and supporting mods right away. As far as I know you need the extension longer chain and longer brake line to pull this off, is that correct? Can someone tell me what some good brands are and where to buy? Also when you guys buy stands do you get the head stand for the front or the spool stand?
Wheelie
Old Man
posted August 19, 2011 05:12 PM
if you get roaring toys extensions you don't need a longer brake line.
wee
Wheelie
Old Man
posted August 19, 2011 05:13 PM
I use a pitbull on the rear, old hinde on the front
wee
Wheelie
Old Man
posted August 19, 2011 05:14 PM
I get most of my stuff from superbikesupply.com call for prices.
wee
BrucerZX14
posted August 19, 2011 07:57 PM
I used the stock brake line on an 8 over McIntosh arm. A little modification to the banjo fittings and it fit perfectly. My arm came with threaded spool mounts so that's what I use. Works with several different lifts.
