BIKELAND > FORUMS > ZX-14.com > Thread: lcd 100 mount NEW TOPIC NEW POLL POST REPLY
horsinaround
posted July 31, 2011 03:28 PM
lcd 100 mount
What is everyone using for lcd 100 mounts ?? I am running a gpr stabilizer so I cant mount it in the stem. I have seen the tech mount euro mounts that clamp to the fork tube but Iam not sure how good they work. What else is everyone using or doing ??
Any info is appreciated.
Rook
posted August 01, 2011 01:12 AM
velcroes to the triangle shape with dimples to the outside of the speedo or the tach. Plenty of wire to make it from under the seat connection to PCV, under gas tank up ram air tube to instrument cluster.
I plan to fashion some sort of bracket that will fit over the triangle shape so the screen is angled to my view . Only prob, then I believe the clutch lever will contact the screen if I turn almost to the lock---which I do when parking the bike.
Another place I considered was the control pod on the left. Tech mount had a mount that was held on by the two screws that fasten the controls.
I would prefer a stationary mount to one that pivots with the steering. Also, you do not want anything that is to low or out to the side too much or you will have a hard time reading.
posted August 01, 2011 05:46 AM
I had a bracket made for the frt tank cowl bolt, but a steering damper may interfer with that as well
horsinaround
posted August 01, 2011 06:01 AM
Yea my options are limited. I ordered one of them tech mount euro mounts that clamp to the fork tube,. We will see how that works out. I dont think Iam going to like it. There was a old thread I found on here with a member saying he made his own locking mount that put it right in his line of site when he was tucked. Maybe he is still on here and will chime in.
06redzx14
posted August 01, 2011 07:26 AM
I plan to mount mine like this, but haven't got around to making the bracket yet.
horsinaround
posted August 01, 2011 09:03 AM
Thats pretty much how it will mount with the tech mount euro mount. Maybe it will work out good for me. it should be here by the end of the week it says. I will post some pics when it comes in.
0.22871994972229 seconds processing time
