BIKELAND > FORUMS > ZX-14.com > Thread: PC-5 mounting NEW TOPIC NEW POLL POST REPLY
cbx1260cc
posted July 31, 2011 09:56 AM
PC-5 mounting
Those who have done the process could you please provide suggestions on the best location for the PC5 to keep it out of site and safe from vibration damage etc.
Thank you
posted July 31, 2011 10:56 AM
It comes with directions. They reccomend you mount it to the ram air tube. I mounted mine under the seat for easier access.
Wheelie
Old Man
posted July 31, 2011 11:02 AM
Ricardo, I mounted mine under the seat like eklipse636
wee
Audioboyz
posted July 31, 2011 01:17 PM
I did mine on the ram air tube.I just have a couple screws on the cover to take off.Pull it out and connect to the laptop.But I don't change maps that often.There are only two different Brocks maps I change too.I'm happy with the one I got so I'm done untill I get a dyno tune.
Craig
2009 Monster ZX-14
Brocks Alienhead,PCV, flys out,LSL Riser kit,-1 front sprocket,43 Vortex rear sprocket,K&N Air Filter, Zero Gravity tall smoked screen,block off plates,175HP 104 torque
Quarter Pounder
with Cheese
posted July 31, 2011 03:30 PM
Mine is under the seat also. Much easier to get at, but it does take a little longer to install in that location. Depends on what you are going to be doing with the bike.
If you plan on dropping in a map and just riding it...put it up front. No worries about "vibration damage". Not sure what prompted that thought.
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
Rook
posted July 31, 2011 05:38 PM
Have had mine underseat for 2 years. Really glad I chose this location. I would say it is accurate to say underseat is ~10x more complicated than the ram air tube but I still think it is very worth it for the easy access and it is just cool to pull the seat up and see all you electronics.
Here is a tutorial with all the details.
http://zx14ninjaforum.com/messages.cfm?threadid=CB3D3987-1372-66AE-3BE3B16BC01CC701
Rook
posted July 31, 2011 05:44 PM        Edited By: Rook on 1 Aug 2011 01:47
There is is just barely enough wire to do it.
I put all my lectronic junk under the seat.
BrucerZX14
posted July 31, 2011 06:32 PM
No room under my seat after all the nitrous stuff got installed. Mine is on the ram air tube. Easy enought to get to but I have two maps in it so no need to keep taking it out.
NINJA12
posted July 31, 2011 07:13 PM        Edited By: NINJA12 on 1 Aug 2011 03:14
mount it on ram tube!
Leave the cord attached and run it under the seat.
posted August 01, 2011 05:52 AM        Edited By: dubious on 1 Aug 2011 14:38
I left the usb wire connected and tucked away, then made a cover using shrink tubing for the usb end, and pinched it closed with pliers while it was still hot and shrinking.
Works great.
I also put the speedohealer under the guages on the aluminum headlight bracket, so i can adjust it, with out digging it out, and I can verify which program it is on, easilly. the recal button has the wire ran inside the pinch on my clip ons, and its tucked away nice but mounted solid
Ill post pics in a few days when I get home.
cbx1260cc
posted August 01, 2011 06:31 AM
Appreciate all the input/replies.
ROOK--Many Thanks for the link. Will be most helpful come install time.
I'll give consideration to my access needs and mount accordingly.
Thank you to all who offered their input.
Ricardo
0.2273108959198 seconds processing time
