3000psi and falling
posted July 08, 2011 03:46 PM
Puig Racing wind screen fitment
I just test fitted my new Puig Racing windscreen on my new OEM fairing, the fitment is very poor, sending it back and will look at other brands. Its the correct part number, did I just get a bad one or have others had fitment issues with them?
Lacker 14
posted July 08, 2011 04:46 PM
I have had a few and never an issue.I like the screen,because its close to stock thickness.
Audioboyz
posted July 08, 2011 05:08 PM
I just got my Puig DB today.I thought the same thing the way all the holes ligned up.But after working it around after getting the top 2 bolts in it worked.You just got to work with it.
Craig
2009 Monster ZX-14
Brocks Alienhead,PCV, flys out,LSL Riser kit,-1 front sprocket,43 Vortex rear sprocket,K&N Air Filter, Zero Gravity tall smoked screen,block off plates,175HP 104 torque
3000psi and falling
posted July 08, 2011 07:35 PM
quote: I just got my Puig DB today.I thought the same thing the way all the holes ligned up.But after working it around after getting the top 2 bolts in it worked.You just got to work with it.
Craig
I can get all the bolts in, but the holes are so far off that the bolts go in at an angle, I tried to install it in my old fairing with the same problem.
MJ
posted July 09, 2011 06:26 AM
I put a Puig DB on mine a few years ago and it fit and looked great. High quality thick well made screen. I wonder if the companies gotten cheap on us lately? I was thinking about getting one for another bike....maybe not so much now?
BIG BLUE_ZX14
posted July 09, 2011 11:42 AM
I had the same issue. The first Puig DB screen the hole alignment was so bad (off by more that a 1/4 inch) that I couldnt mount it and thus sent it back. The replacement screen was not a perfect fit but mountable. Just the other day I removed my windscreen to zip tie the tip over sensor and discovered that one of the middle mounting holes had broken off. That should not happen as the middle mounting areas are under the least amount of stress.
2007 Blue ZX14 Gone...
Ratfink
posted July 10, 2011 08:09 AM
mines perfect
