BIKELAND > FORUMS > ZX-14.com > Thread: Mike & Feeler for valve adjustment NEW TOPIC NEW POLL POST REPLY
Rook
posted July 04, 2011 10:57 AM
Can anyone recommend a specific feeler gauge that will work well to check valve clearance? All i know about them is that they come in various quantity of blades.
I was planning on getting a micrometer also. I can get a Starrett for ~$100 but i hear a $20 Harbor Freight will work as good foe occasional use.
Rook
posted July 04, 2011 12:07 PM
http://www.bikemaster.com/bmstrv2.nsf/Products/B28A389A761CAABF862576FE005CA3D2?opendocument
^^the 32 blade? Does that look like what I need or should I look for something with more blades or longer blades?
open to suggestions on micrometer too.
Big_T112
posted July 04, 2011 12:23 PM
Get a set from the auto parts store with the 45 bend on the end. A cheap feeler gauge will work. No more than you plan to use it. you can even get some digital calipers if you want.
Rook
posted July 04, 2011 01:34 PM
Thanks, Big. Looks like there is a feeler like you describe in the link on my last post. It seems more like a 30 degree bend which looks like it would be easier to reach under a cam. The straight blades, you would have to bend to go under the cam.
I'm staying away from digital for a distance measuring device. Read where someone claimed they can be way off in a certain range of the measurement. --However, if I am willing to consider a HF analogue mike, I should not turn my nose up at a high quality one just because it is digital.
Quarter Pounder
with Cheese
posted July 04, 2011 06:15 PM
so who's Mike?
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
Big_T112
posted July 04, 2011 07:40 PM
Mike the Knife. can't remember which movie that was from.
Rook
posted July 04, 2011 08:32 PM
Actually, it's Mack. You know, good friends with old Lucy Brown.
Rook
posted July 04, 2011 08:33 PM        Edited By: Rook on 5 Jul 2011 04:35
And that is a perfect song for my 14 BTW. Always thought it looked just like a like a shark.
So,,,,,,,what kind of Macrometer should I get?
horsinaround
posted July 05, 2011 06:50 AM
thats all I use. A 45 degree set from I think craftsmen. Works well.
Big_T112
posted July 05, 2011 07:58 AM
No it was a movie not a song. it was a comedy
Rook
posted July 05, 2011 02:19 PM
I guess it would make sense to try to get a set of blades that will include the entire range of thickness that the shims come in. What range of measurement should I look for? I know that I might need to go back and buy a second feeler gauge But I would feel better knowing what is a good tool to start with. ---so I don't buy a 36 blade gauge only to find that 34 of the blades are far bigger than anyone would ever need.
Big_T112
posted July 05, 2011 08:05 PM
Look at your valve clerance range and buy accordingly.
0.22979307174683 seconds processing time
