BIKELAND > FORUMS > ZX-14.com > Thread: 8 weeks Turbo is home. some of the Chinese farings installed NEW TOPIC NEW POLL POST REPLY
Big_T112
posted June 05, 2011 05:56 PM
Went up Saturday to finally get my Turbo Busa project back. It has been at the dyno shop for 8 weeks, The April 27th Alabama tornado's had torn up the area and the Dyno was damaged by flooding. Anyway it was 110 degrees at the shop. Using an ECU flash with a powercommander and a hub hooked to a 3 bar GM map sensor for boost reference the bike made 332 RWHP on Av gas and 161 ft. lbs. torque. He has it so crisp it idles and runs like a stock bike. I installed some of the Chinese farings I had bought. First they do not fit as good as factory. You will have to slot some holes and trim a bit. On my I had to cut out for the air filter and the up pipe. I decided not to use the tail section and get a extended tail section. It still needs to be finished and then a good clean up. Mabe I can finish it and ride it to work by Friday. Here are a couple of picks.
1badzx12r
posted June 05, 2011 06:05 PM
when riding to work ..i don't think turning left is a good idea ..you may lose something ..
01smokes
posted June 05, 2011 06:58 PM
How much boost did it take to make that 331hp?
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
horsinaround
posted June 05, 2011 07:08 PM
Clean bike..I like it. Impressive power. Whats done internally to the motor ???
Big_T112
posted June 06, 2011 07:15 AM
right at 13-14 lbs. of boost. The motor has Falicon rods, 8.8:1 comp Turbo pistons, mild port work/clean up, 65 lb. valve springs, stock cams w/slotted sprockets, Robinson industries HD output shaft with undercut trans, pro mod Busa Cylinder studs and nuts. lockup clutch. It started as a junk yard special.
Big_T112
posted June 06, 2011 09:23 AM
It started out as a salvage non running Busa but it had a clean title.
Ugly paint. should be a fun street ride now. And I don't plan on having it leaned over far enough to hit the filter anytime soon. It's for strait line.
horsinaround
posted June 08, 2011 09:07 PM
Nothing wrong starting with a junk yard dog...those are the fun ones lol Keeps it more reaslistic price wise....at least thats what we tell ourselves when we start the project !!
horsinaround
posted July 03, 2011 08:28 PM
what are you running for a turbo / turbo kit ??
Big_T112
posted July 04, 2011 12:32 PM        Edited By: Big_T112 on 4 Jul 2011 20:35
A GT28R dual ball bearing with a ported exhaust housing, 255 LPH. external pump, 3:1 BEGI 2025 rising rate FMU, MPS 62 lbs. hr. fuel injectors, Reflashed stock ECU with a mapped power commander using a hub, and a 3 bar GM map sensor for boost reference through the hub. The header was from a velocity stage 2 hit, I made all the rest of the piping, It has a Tial 38mm external wastegate. simple setup. rides like a factory streetbike with just more power.
horsinaround
posted July 05, 2011 06:46 AM
For the cash you have into it its very impressive !! A sleeper too...It dont look like a low 8 second bike.
Big_T112
posted July 05, 2011 08:05 AM
Yea, the Chinese farings make it look cheap and I left the stock mirriors on. The aftermarket rear shock helps alot to. It's just got a lot of power. Fun to ride.
MJ
posted July 06, 2011 07:13 AM
I like it!!
0.22900295257568 seconds processing time
