BIKELAND > FORUMS > ZX-14.com > Thread: shimming in frontend after tire change NEW TOPIC NEW POLL POST REPLY
SAYWHEN99
SAYWHEN!!!!
posted June 15, 2011 03:51 PM        Edited By: SAYWHEN99 on 15 Jun 2011 23:53
I had a new shinkio front tire put I'm I even had the balance it twice but at 45 to 50 mph u get a slight shimmy now this started after the new tire was installed please the old tire was a shinkio stealth an the only reason I changed the tire was because it ha no wet traction
01smokes
posted June 15, 2011 04:20 PM
Is it the same size tire as your old one?
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
wrongway
posted June 15, 2011 07:18 PM
check the alignment on the rear tire
tuusinii
posted June 15, 2011 10:20 PM
Sometimes the tire can be put on without care and be badly bead. One thing to try is take the tire of and reinstall it. I've also one time had one tire that was in the end propably foulty and I got a new tire from the manufacturer and after that everything worked. And by the way if You want a tire that is good also in wet - get Michelins. And I normally change both ends at the same time even if the front one will wear less. This is because the tires has so big change on the turning of the bike that it's worth it to use the extra 50-70$ on new front tire even if it has some thread left.
SAYWHEN99
SAYWHEN!!!!
posted June 16, 2011 09:00 AM
Yes its the same size tire even had them take it back off an balance it again. It's on the front
SAYWHEN99
SAYWHEN!!!!
posted June 16, 2011 12:25 PM
I am starting to wonder if there balancing machine is out of calibration cause we have checked everything from the axles to the fro t forks an for it to only shimmy between 50 to 65 mph it has to be out of balance what u guys think
INTIMIDA2OR
RED rider!
posted June 16, 2011 01:38 PM
Bad tire.
'06 Passion Red ZX-14
*Lee*
LOCK 909
posted June 19, 2011 07:03 AM
Try a diffrent tire same brand if you you have to, or what was done wrong when reinstalling the tire , wheel , steering head bearings? Alingment ? .
Bet it's that shinky.
TEC1
posted June 21, 2011 02:19 PM
TRY A MATCHING NEW REAR TIRE IF OTHER OPTIONS DON T WORK OUT
0.26458096504211 seconds processing time
