BIKELAND > FORUMS > ZX-14.com > Thread: clutch question... NEW TOPIC NEW POLL POST REPLY
joel787
posted June 14, 2011 02:34 PM
clutch question...
it fibers came two with corners brown then 7 purple...does it goes on a specific order?
LeonidasZX14
posted June 14, 2011 02:47 PM
Dude, try and throw together a complete phrase and I am sure ALL would be willing to help. That jibber is not comprehened by most.
09' ZX14
dakota9498
posted June 14, 2011 02:48 PM
+1 my head hurts
2008 ZX14
Wheelie
Old Man
posted June 14, 2011 02:58 PM
he may not speak good English and is doing his best, but yes a little more clear for precise help please
wee
LeonidasZX14
posted June 14, 2011 03:17 PM        Edited By: LeonidasZX14 on 14 Jun 2011 23:42
wee
No esta problema, se habla espanol!
09' ZX14
Wheelie
Old Man
posted June 14, 2011 03:44 PM
wee
Boricua?
wee
joel787
posted June 14, 2011 04:54 PM
haha yeah man....dicks but anyways...i bought a clutch pack, fibers and steels fibers came painted on the sides wich i think is cuz they have to line up, 2 of them was brown the rest purple just wondering if they go in a specific order or just trhow them in there...
starchild
posted June 14, 2011 05:49 PM
hey joel there are two fibers that are diffrent... 1 is the oversized fiber and that would be the very first one.... there is a second one that has a diffrent fiber pattern than the others that one i beleive is the seventh fiber .. if you have a manual you should check to be certain i have always placed that one seventh.. good luck
jay
starchild
posted June 14, 2011 05:52 PM
p.s i would not rely on any color code
jay
joel787
posted June 14, 2011 06:19 PM
thanks man apreciate ur help...ill check that tomorrow i wasnt really sure and didnt want to mess anything up...already broke a one of them spring screws so im on my toes now..
joel787
posted June 15, 2011 06:23 PM
So am trying to put some spring and spacers on the clutch, but the factory torque specs are not working...6.8lbs how much should i use
INTIMIDA2OR
RED rider!
posted June 16, 2011 01:53 PM
+1!
'06 Passion Red ZX-14
*Lee*
INTIMIDA2OR
RED rider!
posted June 16, 2011 01:58 PM
The clutch springs don't need much torque . Just by hand untill tight is good enough.
*Lee*
LeonidasZX14
posted June 16, 2011 02:01 PM        Edited By: LeonidasZX14 on 17 Jun 2011 00:53
The small fiber goes in first and should sit perfectly around the anti chatter rings. All the other fibers and steels are the same except the last one which has more fiber contact area and it goes in last (closest to the clutch cover). Put the pressure plate back on and then insert the springs. You may need to push in the pressure plate pretty hard so that the fluid leaves the slave cylinder and goes back up into the resevoir. Install the springs and then put the spacers on with the bolts. You may need to keep pressure on the pressure plate in order to keep the fluid out. Once you do all of this tighten all of the bolts down in an offset order so that the plate seats evenly. I personally don't use a torque wrench I just make sure that they are good and snug. Hope this helps.
09' ZX14
joel787
posted June 16, 2011 05:21 PM
the clutch springs don't need much torque . Just by hand untill tight is good enough
found out the hard way...
zixxer14
Damn that was Quick
posted June 16, 2011 08:06 PM
Time to hit ebay for some used parts.
0.24205207824707 seconds processing time
