BIKELAND > FORUMS > ZX-14.com > Thread: Looking for a Flies out map NEW TOPIC NEW POLL POST REPLY
3000psi and falling
posted June 09, 2011 07:46 AM
Ive just installed a pc-v and am removing the flies after years of riding with them.
I have slip on r-77 and a bmc street filter. Does anyone have a proper map for me to use for now?
joel787
posted June 09, 2011 07:48 AM
Dynojet page got some
3000psi and falling
posted June 09, 2011 07:52 AM
, I was told they are shoty at best lol, but if there close enough...
joel787
posted June 09, 2011 07:59 AM
Yeah but better that than nothing i think...
3000psi and falling
posted June 09, 2011 08:09 AM
I think I found a similar tune on dynojets site, ill give it a shot soon as i get the pesky screws removed and get this bike back togather.
LAB3
posted June 09, 2011 08:13 AM        Edited By: LAB3 on 9 Jun 2011 16:15
Soldering iron to heat screw.........JIS screw driver or New Craftsman, Snap on etc.
regular phillips that has never been hurt...still fresh tip.
joel787
posted June 09, 2011 08:16 AM
Yup...be careful i wonder what went wrong...
3000psi and falling
posted June 09, 2011 12:26 PM
I got em out! I bought a néw Kline 7 inch #2 screwdriver, heated each screw with a soldering iron and they came out like they were made of butter! Can't wait to see what all you guys have been talking about all these years!
3000psi and falling
posted June 10, 2011 09:27 AM
Test rode this morning, lots of popping and its much slower than when my wallet was 300.00 heavier than it did with the stock tune and the flies in. The map im using is from dynojet in the description it says 06-07 slip on flies out stock or aftermarket filter. Being that mine is an 08 Im thinking that may be an issue? Called fuel moto again this morning for the proper map but was reffered to the map request email again. I have a weekend long ride to attend am am kinda screwed right now.
LAB3
posted June 10, 2011 10:03 AM
Did you trying riding it with the PC disconnected? Just for the week end I don't think the A/F will be off so bad to hurt anything. Mike's PC3 went bad on a trip in Arkansas, we disconnected it and he has a full 4/2/1 exhaust system and ran OK. He lost a few bike lenghts on roll on's :-) but other then that it ran smooth. Was the popping on deacell at about 3500 RPM????
3000psi and falling
posted June 10, 2011 11:06 AM
Yes the popping is in the lower range, I will disconnect the pc and test.. thanks
Audioboyz
posted June 10, 2011 12:45 PM
Get a Brocks pipe end of popping.I still can't believe mine runs so good.
Craig
2009 Monster ZX-14
Brocks Alienhead,PCV, flys out,LSL Riser kit,-1 front sprocket,43 Vortex rear sprocket,K&N Air Filter, Zero Gravity tall smoked screen,block off plates,175HP 104 torque
LAB3
posted June 10, 2011 12:48 PM
Pm sent.
LAB3
posted June 10, 2011 12:54 PM        Edited By: LAB3 on 10 Jun 2011 20:55
Craig
Craig on the 2006/2007, secondary flies removed and with a Brocks pipe and map you will notice a pop on deacell at about 3500 RPM. Some 14 owners plug the tube to air box and install block off plates to help cure this.Some purchase a Brocks or Ivans TRE to cure this. Read on brocks site about this. If you 14 is not doing this and you installed the pipe and map you are lucky.
Louis
Audioboyz
posted June 10, 2011 01:09 PM
His is an 08 should be the same as an 09.When I was running 2 Bros slipons with flys out and PCV it popped like crazy.Guess I am lucky but maybe it's the good Brocks maps.
Craig
2009 Monster ZX-14
posted June 10, 2011 01:29 PM
Buying a brocks pipe isn't going to stop the popping. Mine still pops. When jones performance tuned mine it helped, but still shoots out a good flame occasionally. It dosent hurt anything, just extra fuel not being burned.
0.25515580177307 seconds processing time
