BIKELAND > FORUMS > ZX-14.com > Thread: Dynotune Nitrous window switch...Tach signal? NEW TOPIC NEW POLL POST REPLY
pazx14rider
posted May 26, 2011 07:27 AM
Anyone using a Dynotune Rpm window switch tell me what wire they are using for the tach signal. I have a MSD shift light with a pick-up hooked into coil #1 (white/red) wire shift light works great. tried hookind the window switch into the same wire without a pickup and no luck. dont know if its too much interference or what. I have a spare pick-up from MSD possible to use that to help pick up a clearer signal or not? Any help on this would be great thanks!
dakota9498
posted May 26, 2011 08:46 AM
I am using a Dynotune Progressive with a window switch and I picked up the signal from the #1 coil wire (white/red), not sure why that wouldn't work. I don't have an MSD shift light, I run a Raptor Dual Mode Shift Light but it uses the same wire.
2008 ZX14
BrucerZX14
posted May 26, 2011 11:29 AM        Edited By: BrucerZX14 on 26 May 2011 19:31
I have the Dynotune RPM window switch. Doesn't have progressive controller.
If yours is just the RPM window switch, what setting was the tach signal set to in the RPM window switch? It would be step 1 on the programming. Using just the one negative signal from the coil, it should be set at 1.
If you have the RPM switch w/progressive controller, in step 5 it is set to 1.
I'm picking my signal up off #4 negative. I also pull my Raptor shift/launch light off the same wire.
pazx14rider
posted May 26, 2011 05:52 PM
Its just a RPM window switch...I will check that setting that could be the problem thanks guys for the response
0.22254514694214 seconds processing time
