BIKELAND > FORUMS > ZX-14.com > Thread: tiger tail? NEW TOPIC NEW POLL POST REPLY
joel787
posted May 21, 2011 05:21 PM
tiger tail?
Anybody got one? Got a nice hole on my under tail, not too clear in the pic but some plugs and cables are showing.
[IEMG]http://i1180.photobucket.com/albums/x410/joelcabrera10/IMAG0154.jpg[/IMG]
joel787
posted May 21, 2011 05:39 PM
posted May 21, 2011 05:50 PM
I could be Wrong, but isn't that hole already in the tail?
You havent rubbed it enough to cause damage, why don't you raise the rear up a little bit?
joel787
posted May 21, 2011 06:04 PM
Yeah already went one inch up, just found out...so when is danger?
Compton
posted May 21, 2011 07:17 PM
danger is when your wires are done and computer is toast. put a tiger tail on it and dont worry about it.
b.w.
posted May 22, 2011 01:48 AM
Also you can tighten the spring on the rear shock up, and tighten the screws on the rear shock
joel787
posted May 22, 2011 10:06 AM
I think the extra lift a gave it it should be ok, i dont have too much tire left to be tightening the suspension yet. Lol
CraigChrist
BAWLS
posted May 22, 2011 10:37 AM
if you have an old motorcycle license plate, you can also bolt it up under there to project your ecu until you get a tiger tail
60ft-------1.42
1/8th------5.97
mph-------119
01smokes
posted May 22, 2011 01:15 PM
Hahaha I did that same thing with the turbo bike. The ECU fell out of the hole once lol good times with the old blue bike lol
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
joel787
posted May 22, 2011 02:16 PM
Ha..ill sacrifice my cars, its for a good cause
posted May 22, 2011 05:35 PM
What does the amount of tire have to do with you making the shock stiffer and stopping it from bottoming out?
joel787
posted May 22, 2011 05:45 PM
Well i do hove my suspension set some, but im pretty sure that on the street the stiffer the bike more impact the tire takes
Dale
posted May 22, 2011 06:52 PM
You might be able to get used one
2007 Kawasaki Ninja ZX-14 Special Edition Turbocharged
posted May 23, 2011 01:52 AM
Ok...... That's about like saying that a swb bike will eat the tire faster than a stretched bike. When you stretch it, the suspension has to work harder because of the leverage. You stiffen it to compensate for the swingarm.
Btw, please don't say something like that again.."don't adjust suspension because of tire wear".
joel787
posted May 23, 2011 07:30 AM
I didnt mean it like that, but yeah obviously i need a better setup. I have 2 1/2 turns on the screws, so maybe 2 turns on the spring and 3 on the screws?
01smokes
posted May 23, 2011 07:44 AM
Stiffen it as much as you can...
joel787
posted May 23, 2011 10:59 AM
All the way on the spring?
01smokes
posted May 23, 2011 11:12 AM
Yep
posted May 23, 2011 06:05 PM
Yep
The stock spring isn't stiff enough. With replacing the spring and revalving the shock your networking with much. Just try and make chicken salad out of chicken shit.
0.2181179523468 seconds processing time
