BIKELAND > FORUMS > ZX-14.com > Thread: Removing chain guard bracket? NEW TOPIC NEW POLL POST REPLY
Sheard
posted May 16, 2011 05:06 PM
There is a bracket on inside of swing arm that hilds on chain guard. Has anybody cut this bracket off? I have extensions, seems like chain might get into is, if there a little slack. My chain guard only attaches to outside mount bolts. Do chain guard have to attach to inside bracket?
posted May 16, 2011 06:04 PM
I dont think it will hit, mine never has. I've never heard of anyone cutting it off. No need.
posted May 16, 2011 06:18 PM        Edited By: Shane661 on 17 May 2011 02:18
I had the inner bracket cut off of my extended arm. That inner bracket can hit the tire, depending on how your wheelbase is set. The Tiger Racing chain guard only uses the outer two screws.
The chain should not be an issue though.
Superman T
posted May 16, 2011 06:22 PM
I cut mine... after extending my bike the length put the outer rim of the rear tire in direct alignment of that bracket. I cut it 3 years ago with no issues
dakota9498
posted May 16, 2011 06:23 PM
I cut mine off, not for clearance reasons, I just didn't like the way it looked. Plus it was unwanted weight.
2008 ZX14
Sheard
posted May 16, 2011 07:39 PM
i gunna chop it then. thanks
posted May 17, 2011 01:48 AM
Well hell... I guess I was left out of the loop on cutting that off.
NinjaNick
'08 ZX14 (Blue)
posted May 17, 2011 02:28 AM
Is this on the stock arm that people are having issues with when using extenders?
If not, what arm is this an issue with?
Superman T
posted May 17, 2011 03:01 AM
Stock Nick
NinjaNick
'08 ZX14 (Blue)
posted May 17, 2011 03:07 AM        Edited By: NinjaNick on 17 May 2011 11:08
Figured, just was checking.
0.24490118026733 seconds processing time
