BIKELAND > FORUMS > ZX-14.com > Thread: 09 stock zx14 temp guage pegged at high NEW TOPIC NEW POLL POST REPLY
posted May 12, 2011 10:37 AM        Edited By: dubious on 12 May 2011 19:49
Temp guage gets pegged on high, (but does not flash) pretty easy in city rides, only 75F outside.
Is this normal with stock fender, and stock exhaust?
Just making sure as the bike has a used unit 30 day warrantee,
and Im about to start modifying the bike
I dont recal my stock 2006 running past 3 bars, maybe 4 bars, but it was not stock for long.
I bought another zx14,
2009 with 3700 km on it. Its totally stock burned orange limited edition
I noticed it has warped front rotors once they are warm
wont even bother with the dealer an warrantee on that, just gonna call Cory for a set.
The plan is a lighter, but stock zx14 for reliable super sport touring.
CNC headwork,
47mm throttlebodies
Brocks Titanium CT duals
PC5
Speedo healer
16 tooth'
zx10 fender
Undertail
windscreen
Raised clip ons
stainless brake lines
eventually a 4mm stroked crank too maybe
gumbybob
posted May 12, 2011 11:04 AM        Edited By: gumbybob on 12 May 2011 19:06
My '07 frequently goes to one bar below high in heavy traffic. I live in New Hampshire, so it's not brutally hot here either. Always runs fine but quite unsettling. In a way, I wish I could turn off the temp gauge just so I don't fixate on it so much. But I know it's a good thing to have. And I have a full Akra, PC, custom map, flies out yada, yada.
I'm wondering just how accurate the gauge we have is considering some people (like you, Lyle) say they have had 14"s that never get above 3 bars and others like me seem to run on up to the top in traffic. And if the problem is only in heavy stop & go (1st gear) traffic, the ZX10 fender (which I have, thank you) probably would not help.
Is there an actual gauge with either analog or digital readout that can be attached? That way we'd know the actual temp and when to start worrying.
Audioboyz
posted May 12, 2011 11:16 AM
I try to stay out of traffic.Everthing about it sucks from the too hot full face helmet to my leather jacket and the heat from the motor.I like when I hit the open road over 70 nice cool air pleanty of power out of my Brock.Thanks to everyone here for steering me to Brocks pipes and maps.From 3 grand to way up it just pulls.I was coming out in first and shifted early and nailed it in second and I don't remember shifing to third it happened so fast.Sorry off topic.
Craig
2009 Monster ZX-14
Brocks Alienhead,PCV, flys out,LSL Riser kit,-1 front sprocket,43 Vortex rear sprocket,K&N Air Filter, Zero Gravity tall smoked screen,block off plates,175HP 104 torque
CraigChrist
BAWLS
posted May 12, 2011 11:17 AM
that's not normal... mine didn't do it with the stock pipes and fender, and I got stuck in traffic in arizona on my way from texas to san diego in 100 degree temps. It would however go 1-2 bars from the top and stay there no matter what.
60ft-------1.42
1/8th------5.97
mph-------119
dakota9498
posted May 12, 2011 11:27 AM
Mine ran pretty hot, you have to remember that the 08 and up have an extra catalytic in the header, whereas the 06-07 only had them in the mufflers.
2008 ZX14
posted May 12, 2011 11:48 AM
10-4 ,
well the brown van just showed up with my CT dual exhaust , PCV , 16 tooth, and flyless TRE
Not a big fan of duals, but it makes the same power up top, and 6HP more midrange.
I would still have gone single, but this bike is for advertising my business, so need to represent all the options I guess.
Is it possible to polish Titanium?
LeonidasZX14
posted May 12, 2011 03:16 PM
Lyle, my 09 ran very hot down here in Florida. I have had it as hot as the top bar plenty of times and I really did not like it either. The bike seemed to always run at 4 bars and as soon as I would stop in traffic it would peg the top. As far as polishing Titanium it can be polished but DO NOT use aluminum polish such as Mothers it will scratch it pretty bad. I know of a chrome shop here that polishes Titanium.
09' ZX14
1badzx12r
posted May 12, 2011 03:38 PM
i ain't gonna say nothing since i never owned an 09.. but an air pocket in the cooling system made mine run hot ...but i live in texas .. everything hot in texas ...
INTIMIDA2OR
RED rider!
posted May 14, 2011 10:00 AM
Possibly low on coolant , fan not working properly , stuck thermostat.
I had a bike in my shop recently that had a fan that worked fine when it was cool or warm. When it got hot the fan would malfunction by stopping and starting and turning slowly or not at all.
Had a 14 one time that had the over flow tank hose improperly routed so it was rubbing on the fan. It resulted in the coolant tank always being full but the radiator was only Half filled .
I thought it was strange thay it Didn't over heat though.
'06 Passion Red ZX-14
*Lee*
posted May 14, 2011 12:33 PM
Thanks guys, I wil investigate further through process of elimination.
First thing I'll check is over flow routing,
level shows good, will check rad when its cool too.
add some water wetter.
pipes, and map
fender
which reminds me to order a rad guard....
been there before already
gumbybob
posted May 14, 2011 04:14 PM
Keep us informed,Lyle
This affects a LOT of us.
Dale
posted May 14, 2011 07:11 PM
Hey Lyle, mine did that when it was new but it never overheated only ran hot in stop and go traffic. If memory serves me correctly it went away around 500 miles.
2007 Kawasaki Ninja ZX-14 Special Edition Turbocharged
epd345
posted May 15, 2011 04:41 PM
Lyle my 07 ran one down from being pegged while stuck in traffic. Never higher than that. I ride in the New England and that was probably a 95 degree day which is about as hot as it gets. With over 11k on the clock now seems to run cooler than when new.
Dale
posted May 16, 2011 04:35 PM
Nice ride their epd345. Nice to see another 07 SE!
0.34220814704895 seconds processing time
