BIKELAND > FORUMS > ZX-14.com > Thread: Wet nos install questions NEW TOPIC NEW POLL POST REPLY
06redzx14
posted May 09, 2011 06:17 AM
Getting tired of fighting a fuel issue with my dry setup. Thinking about switching to wet. How and where should I put the foggers and extra fuel pump? Drip plate or tap the tank?
NINJA12
posted May 09, 2011 09:50 AM
I have not done it yet, but there is room in the battery box for pump and solinoids.
If you don;t mind a little drilling you could hit the airbox from the battery box side.
I prefer to tap the pump plate, as to not create problems with the tank..
Dry has worked very well for alot of people. How are you switching maps?
How much you trying to spray?
kaw-rick
posted May 09, 2011 11:49 AM
I usually tap into the tank, put fuel pump right under tank. i put nozzles in air box and spray down the stacks. i like wet better for the same reason your wanting to switch.
kaw-rick
posted May 09, 2011 11:51 AM
Btw i ran a 100 shot for 4 yrs, no problems. stock engine.
06redzx14
posted May 09, 2011 07:33 PM
I've sprayed 70-80 dry. Going to give it one more try on the dyno just installed a new walbro pump
posted May 12, 2011 12:00 PM
100 shot , whats that equal, about 2 lbs per 1/4 mile? or 8 seconds?
1badzx12r
posted May 12, 2011 03:39 PM
well
06redzx14
posted May 12, 2011 04:40 PM
Wont be on the dyno til Saturday.
1badzx12r
posted May 12, 2011 05:29 PM
were bouts
06redzx14
posted May 12, 2011 05:36 PM
Third Coast Speed
kaw-rick
posted May 12, 2011 07:01 PM
100 shot=i could get 2-3 good 1/4 mile passes b4 bottle pressure would fall off. i only ran mid 8s at 169 mph. im 220 lbs naked and not really a good rider, only had 1.45 sixty ft.
posted May 12, 2011 07:10 PM
0.28787398338318 seconds processing time
