BIKELAND > FORUMS > ZX-14.com > Thread: my 14 is smoking NEW TOPIC NEW POLL POST REPLY
Meangreen14
posted May 08, 2011 04:22 PM
my 14 is smoking
my 14 started smoking a little last month just a little every time i stoped @ a light i would bleep the throttle & a little puff would come out only once, after that it would not smoke. know every time i get into the throttle a lot when i come to a stop and bleep the throttle it throws a pretty big puff of smoke all the time know. it comes and goes, i rode to Oklahoma last week and it wasn't smoking, anyone have any thoughts?
PCV, quick shifter, stock gearing,
fly's out, custom garrett gt28 stage1 turbo, JE pistons, 625cc inj, MTC lock up clutch,1:1 fuel pressure regulator...
1badzx12r
posted May 08, 2011 04:37 PM        Edited By: 1badzx12r on 9 May 2011 00:37
BEING A TURBO i'd say turbo oil seal
Meangreen14
posted May 08, 2011 04:43 PM
i hope thats it, i noticed today on start up it spit out lil specs of oil from dump pipe on to driveway,
1badzx12r
posted May 08, 2011 04:47 PM
trust me .. 1 turbo man to another .. if it was a piston . there be 1 hell of a oil spill from the breather tube
Meangreen14
posted May 08, 2011 04:58 PM
ok cool, that a big relief! thanks
boostphreak
posted May 08, 2011 08:49 PM
what part of oklahoma did you ride to?
Meangreen14
posted May 09, 2011 02:09 PM
OKC, Nice ride up but on Sunday had to put it in trailer was thunderstorming and real windy & I lost my damn rain sock
Meangreen14
posted July 26, 2011 08:41 AM
found the problem, i noticed my scavenger pump was sounding weird like it was not moving oil thru turbo right, i installed a new pump and no more smoke!!, i hope this one lasts a wile, i've herd they dont last long some times..
Slowninja
Slow-ride
posted July 26, 2011 08:59 AM
Theres a few of us here in oklahoma city. post up next time you make a trip. Glad to hear you got it figured out
06 zx14
SWB
9.24 @ 148
Meangreen14
posted July 26, 2011 09:30 AM
ok cool ill post on my next ride up there
gilberjj
Friend of Fast
posted July 27, 2011 07:23 AM
How many miles did you get out of the first pump? Heat kills them I've heard.
BlackMagic14
posted July 27, 2011 07:25 PM
Meangreen
That is the same turbo I am having installed on my bike. How do you like it and what kind if power does it make? Overall impressions appreciated.
Meangreen14
posted July 28, 2011 11:24 AM
im almost at 6,000 miles, but i got the kit used gllberjj
Meangreen14
posted July 28, 2011 11:31 AM
BlackMagic14
I love the unit, but it was used so know i gatta replace the oil seals on turbo it started smoking on me randomly again...
the bike on 5lb boost makes 218rwhp with a not so good map, motor is all stock, i have to get it remap'd soon, and i have to put an external gate on it its creeping on me to like 9lb wen i get of the throttle after high rpm WOT runs
BlackMagic14
posted July 28, 2011 04:19 PM
hmm, 218 seems a little low. I was hoping for 250-260 on 6 pounds, I wonder if I am being unrealistic. I hear good things about that size turbo as far as how quick it spools and so forth. My kit will have an external wastegate so I am hoping to avoid creep
Meangreen14
posted July 28, 2011 10:38 PM
Ull get close to your goal with a good dyno tune BlackMagic14, my map is to rich,
1badzx12r
posted August 01, 2011 06:00 PM
http://www.majesticturbo.com/ ..i've heard good things from these guys
Meangreen14
posted December 01, 2011 07:16 PM
Ok just got some extra monies to fix bike, so I ride it to my mechanic and is not smoking no more If it were the turbo it would constantly smoke rite? I rode it for a good 20 miles and nothing? I pulled the plugs and they were oily, noticed the inside spark plug gasket on cylinder 3&4 were pinched outside the valve cover holes and it was a pain to take the plugs out because of seal was out so much is there any way this is wy it's smoking randomly oil going in spark plug hole? I ordered a new valve cover seal & the small spark plug seals and ganna have them reinstalled what y'all think?
RICH CRAFT 1
posted December 02, 2011 06:36 AM
there is a drain hole in the bottom of the spark plug hole that let's water and oil drain out the front of the head, if the gaskets were pushed out. It would let oil run through these holes and drain out the front of the motor. Probably hating something hot on your turbo? I have never seen one of these gaskets pushed out. But then I'm not a turbo guy. One thing to check the factory crankcase breathing hose goes into the air box, did they remove this hose and plug the box, if they didn't, that would build boost in the crankcase and pushed the gaskets out. if they did, what did they do with the breather hose? because a turbo is going to push a lot of air pass the rings and that extra pressure needs a good vent.
Ken
Red 06 ZX14 RR
Meangreen14
posted December 02, 2011 10:50 AM
Yes the crank case is not linked to the air box any more, the box was plugged and we put a little filter on the crank case breather. The air box is clean, it has to be oil getting in combustion chamber some where?
oldkawboy
posted December 02, 2011 01:43 PM
I've got a turbo ZRX and mine smokes from time to time.....never too much & never long but it happens.
I checked the major stuff & all is well, just figured some oil is seeping by the seal 'cause it's always on start-up & only happens like once out of every 25 rides. I dunno but all seems fine.
What brand of pump are you using?
Thanks,
Dan
Meangreen14
posted December 02, 2011 06:13 PM
The scavenger pump is cycle logic the little $80 one
0.29411196708679 seconds processing time
