BIKELAND > FORUMS > ZX-14.com > Thread: it died on me NEW TOPIC NEW POLL POST REPLY
joel787
posted May 02, 2011 08:45 PM
it died on me
so today i took my bike out , then hit it out the hole 1,2,3 and it died ... what could it be, everything lights up no error codes, i just felt a strong "clank" but not loud it does not want to start anymore. any help appreciated thanks.
3Boysand3Bikes
posted May 02, 2011 10:35 PM
Not a lot of info to go on here.... but most of the time we heard this over the past 5 years had to do with the power commander. The ground system was a very bad system. Just re-run the ground to a better spot. Many people ran it to the battery. I just bolted it to the grame and never had the problem again. If you don't have a Power Commander, I would guess it was a fuse type issue. This was very common in 06 but most people had gotten it fixed with the ground. hope this helps. If not, keep us informed on what you find. Has to be a wire somewhere. Hope this helps. What I did was bypass the Commander to test it and sure enough, it worked fine.
3Boysand3Bikes
posted May 02, 2011 10:36 PM
oops... I meant Frame.... not grame.... duh....
3000psi and falling
posted May 02, 2011 10:44 PM
Can you give us more info? How long had it been sitting before you rode it? Is there oil in it? Dose the motor turn over when you crank it or is it seized?
joel787
posted May 03, 2011 02:12 PM        Edited By: joel787 on 3 May 2011 22:53
Yup...stupid me it was the pc after all...thanks for tha help..
joel787
posted May 03, 2011 02:55 PM
Too bad i spent $60 on a tow truck...
Rich
Just havin' fun!!
posted May 03, 2011 03:27 PM
Yeah, but good thing it was such a simple fix that didn't cost so much. Unfortunate for the temporary PITA, yes. Over all, not such a bad day, right?
07 Green and Black, How fast is fast?
203 for now. Limited $$ = limited HP.
  Ignore this member    Click here to visit Rich's homepage.
joel787
posted May 03, 2011 03:48 PM
hell yeah man, i thought i had to go burn it and claim it on the insurance...jk
indynic
Lil Show, Lil Go
Oh Rich, you are so positive
Dale
posted May 03, 2011 03:51 PM
Hopefully the PC was under warranty, in the past had 3 fail outside of warranty.
2007 Kawasaki Ninja ZX-14 Special Edition Turbocharged
0.22569704055786 seconds processing time
