BIKELAND > FORUMS > ZX-14.com > Thread: 07 clutch replacement NEW TOPIC NEW POLL POST REPLY
ballsdeep
2007 ZX-14
posted May 02, 2011 04:47 PM
My bike currently has 11,000 miles and I've never replaced the clutch. This is my first bike with a hydraulic clutch so I'm not sure how exactly to tell when the clutch should be replaced. I'm a pretty mechanical guy but tearing into the 14 kinda scares me a little and I don't want to mess anything up. I'm about due for an oil change so should I just crack open the clutch case and pull out some of the discs and take a peek? If I do this is there a gasket on the cover?
I haven't had any issues with shifting. I usually never use the clutch to up shift when I ride and I don't drag race. I think a simple OEM replacement would be best.
Any help is appreciated.
Roaring Toyz extensions|Billet links|ASV levers|Puig screen|DDM 5k HIDs|PC3|Dual Leo Vince slip ons|Flies out|Black wheels|16/43
zixxer14
Damn that was Quick
posted May 02, 2011 05:47 PM
I've got over 34k on stocker with no trouble. Look in the oil hole & you can do a visual on it. No need to open up if you're not having probs. Check the oil for debris. The clutches are not a problem & wear a long time even with abuse.
posted May 02, 2011 06:05 PM
If it ain't broke don't fix it.
ballsdeep
2007 ZX-14
posted May 02, 2011 08:15 PM
Sounds good to me, thanks for the info.
Dale
posted May 03, 2011 04:43 PM
Clutch: Standard Service Limit
Friction Plate Thickness 2.92∼ 3.08 mm (0.115∼ 0.121 in.) 2.7 mm (0.106 in.)
(13088-0030, 13088-0031)
Friction Plate Thickness 3.72∼ 3.88 mm (0.146∼ 0.153 in.) 3.5 mm (0.138 in.)
(13088-0032)
Friction and Steel Plate Warp 0.15 mm (0.0059 in.) or less 0.3 mm (0.012 in.)
Friction Plate Warp 0.2 mm (0.008 in.) or less 0.3 mm (0.012 in.)
(only 13088-0030)
Clutch Spring Free Length 65.0 mm (2.56 in.) 62.0 mm (2.44 in.)
2007 Kawasaki Ninja ZX-14 Special Edition Turbocharged
0.28849697113037 seconds processing time
