BIKELAND > FORUMS > ZX-14.com > Thread: fuel pump or injectors NEW TOPIC NEW POLL POST REPLY
06redzx14
posted April 30, 2011 06:27 PM
I left q16 in my tank from early Febuary til about 2 days ago. I went to tune the bike today on C16 and the bike was showing lean. The duty cycle actually rose to above 60% on motor. I have what I think is a Walbro fuel pump and crushed requlator. My numbers were -20s with q16 and went up to +10s on C16. What should I do clean injectors or change fuel pump?
gilberjj
Friend of Fast
posted May 01, 2011 08:04 AM
If you can get it to run, put in some fuel system cleaner. That costs you less then $20, and almost no time. If that doesn't do any good, then start tearing in!
NINJA12
posted May 01, 2011 01:24 PM
do you have a fuel pressure gauge?
I'd try a quality cleaner , then test pressure to see if it pump or injectors.
Throwing parts is a gamble.
0.48437309265137 seconds processing time
