BIKELAND > FORUMS > ZX-14.com > Thread: zx-14 timing..butterflies NEW TOPIC NEW POLL POST REPLY
wally
posted April 11, 2011 08:31 AM
i do not have the zx clutch lever assembly so i will not be using the starter lock out switch..i was told that the ecu will (?) retard the ignition when the clutch is pulled in so that will determine what to do with the starter lock out wires.....do i wire it to start in gear/neutral or just in neutral?.....will removing the subthrottle butterflies improve top end performance any???
sidecar
slates
posted April 11, 2011 10:15 AM        Edited By: slates on 11 Apr 2011 18:23
wally,
I'm sure some more knowledgeable than i will reply, but removal of the secondary butterflies will not increase top end as the stock version will open them above 6-7K rpm....you will however get a lot more acceleration, from 3 to 7K rpm with them removed because it won't be choking off the air. Don't forget to have a good map for all this extra air going in at lower rpms. Having them out makes the bike more fun and gives you the power you expect more smoothly.
It will also depend on what year 14 you have...I know the above is true for a 2006 and 2007. I think Kawi changed when the 2nd throttlebodies open on the 2008 and forward.
joel787
posted April 11, 2011 01:17 PM
be careful removing them i had fucked it up thinking it was so easy and being careless..
head_zx14ninja
2010 xz14
posted April 12, 2011 01:20 AM
There are a few good threads out there that detail the removal of the flies.
It's not a very hard job but easy to F it up and put yourself in a position where you will be scratching you ass.
Search for removing flies zx14 in google an the first one that pops up should be the detailed one with all the photos.
All I'll say is be patient when doing it.
Martin
“One thing leads to another”? Not always. Sometimes one thing leads to the same thing. Ask an addict.
0.24780607223511 seconds processing time
