BIKELAND > FORUMS > ZX-14.com > Thread: Which way should these be mounted? NEW TOPIC NEW POLL POST REPLY
zx14dreamin
posted March 31, 2011 07:41 AM
http://cgi.ebay.com/ebaymotors/KAWASAKI-ZZR-ZX14R-Ninja-06-08-FRONT-ROTORS-_W0QQcmdZViewItemQQhashZitem5885c21fdbQQitemZ380201213915QQptZMotorcyclesQ5fPartsQ5fAccessories
What direction should the pattern be going? Should there be something on them that indicates the direction they should be rotating?
Rook
posted March 31, 2011 08:13 AM
zx14dreamin
posted March 31, 2011 08:16 AM
Compton
posted March 31, 2011 09:41 AM
this might work
b.w.
GREYHOUNDMOSES
posted March 31, 2011 09:54 AM
They look to be Yana Shiki Rotors.
The pic on the left is the RIGHT rotor.
The pic on the right is the LEFT rotor.
I'm not sure I'd trust them for front rotors but was seriously looking at a rear.
I asked several vendors for the weight and the one reply I got suggested it was the lightest around.
If you do get them, I'm sure several people (including me!) would be interested in you weighing them
before fitting.
GREYHOUNDMOSES
posted March 31, 2011 09:57 AM
Hey Compton. I trust that's not your bike!
If it is maybe you saved a bit more weight by skimping on rotor bolts!!!
Compton
posted March 31, 2011 10:31 AM
Not mine, just a pic i found of the rotors mounted.
b.w.
zx14dreamin
posted March 31, 2011 10:43 AM        Edited By: zx14dreamin on 31 Mar 2011 18:49
They are already on and are mounted BACKWARDS,
the guy that put my tires as a favor from another forum, bent my stock rotors(he paid for the new ones) long story short these are what are on there now with EBC Extreme Pro brake pads which he mounted.
Wierd vibrations and such are happening I have to give them a pump to get rid of it then it goes smooth, regardless they are on backwards and I need to flip them.
I have only run them a few times, should they be ok to run the other way?
I should have told him to get me stock rotors and pads because it was perfect before....sheesh
zx14dreamin
posted March 31, 2011 10:46 AM
Thanks compton for finding the pic!
zx14dreamin
posted March 31, 2011 10:53 AM
Well wait this has the back going one way the fronts another
GREYHOUNDMOSES
posted March 31, 2011 11:05 AM
Shouldn't cause too much harm short term but get them swapped ASAP.
I've learnt the hard way that having people do you "favours" can prove costly!
GREYHOUNDMOSES
posted March 31, 2011 11:12 AM
The back can only be mounted on one side. It must be right.
The fronts on the other hand.............
I fitted EBC grooved discs to my Range Rover and each disc was marked.
The "swhirls" are designed to track brake dust etc. to the outside of the disc.
ie the way centrifugal force is already sending them.
zx14dreamin
posted March 31, 2011 12:15 PM
My rear is facing the wrong way too though :\
That picture I posted is from Yana Shiki web site :\
seems like they should be the other way like the first pic, they guy that put them on also did not have a torque wrench and I am sure did not put high heat lock tight on the nuts....
zx14dreamin
posted April 01, 2011 07:51 AM
So when I got to work this morning I check out my rotors, who vibrated and made whirring noises every time they were applied, and seems there is a score mark on the rotor....:\ I think I am going to have to have a shop look at this
zx14dreamin
posted April 01, 2011 09:37 AM        Edited By: zx14dreamin on 1 Apr 2011 17:56
What is the torque rating for the rotor fasteners?
posted April 01, 2011 05:17 PM
Why dont you call the company that makes them and speak to them directly?
gilberjj
Friend of Fast
posted April 01, 2011 06:00 PM
Because he doesn't speak Chinese!
zixxer14
Damn that was Quick
posted April 02, 2011 06:57 AM
That's bad!
zx14dreamin
posted April 04, 2011 04:12 AM
I believe they are made in Japan but I don't speak Japanese either
zx14dreamin
posted April 04, 2011 05:27 PM
I put them the other way and they still make noise, though once I got them hot, the seem to quiet.....also the dude that put them on, only put the plastic shim that must have come with them on one side, he did not realize they were stuck together so , there is one on each side now, ....so if they hold together through the life of these pads, i will be changing these rotors out if they don't quiet significantly...I also tried to weigh them and they were to light for my scale its a bathroom scale so it really was not made to weigh something so light
zx14dreamin
posted April 05, 2011 07:15 AM        Edited By: zx14dreamin on 5 Apr 2011 15:16
not sure if anyone is reading this anymore, but this morning on the way to work they were much much smoother, might be a combination of them bedding and the direction of the rotor....and me making sure everything was torqued to specs
0.21493601799011 seconds processing time
