BIKELAND > FORUMS > ZX-14.com > Thread: Rear Feels Weird... NEW TOPIC NEW POLL POST REPLY
GHOSTMAN
posted March 13, 2011 05:03 AM
Rear Feels Weird...
Question:
I noticed that when I go into slight right hand turns, the rear end feels like it's trying to ease out. It doesn't do it when I make a left, or hard rights.
I've checked wheel alignment, pressure, and made sure that my suspension was matched up in the front, but it still feels like it has that slight movement.
Any Ideas?
I'm There Whether You See Me Or Not.
kawasakijockey
posted March 13, 2011 07:48 AM
Front tire wear will cause low speed handling differences.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
GHOSTMAN
posted March 13, 2011 07:51 AM        Edited By: GHOSTMAN on 13 Mar 2011 15:52
Didn't make any difference. Did that with new set of tires, balanced. Not sure if I'm positioned differently between right and left or what.
dcjens
Wet side of Washington
posted March 13, 2011 08:24 AM
something to try... check/ flush and replace front fork fluid. I know somebody that had around 6K miles on their bike with similar handling problems. He discovered a watery mess in his fork fluid.
While youre in there, checking tube position in trees as well as compression and dampening might do the trick. I dumped my bike several years ago and found the trees were tweaked ever so slightly. does the bike go straight down the road "no hands" ?
Black 06
GHOSTMAN
posted March 13, 2011 10:05 AM
Yeah, it goes straight with no hands, no wobble. Now that I think of it, I wonder if maxing out the preload has anything to do with it...
0.21093988418579 seconds processing time
