BIKELAND > FORUMS > ZX-14.com > Thread: clock settings NEW TOPIC NEW POLL POST REPLY
Das-T
posted March 12, 2011 12:25 AM
clock settings
On my zx14 I had a secondhand clock on and this clock can`t reset time and the feul gauge keep on flickering and can`t give me the exact amount of feul in the tank...is there any body that can help me with this problem...? THANKS..DAS-T
Das-T
  Ignore this member    Click here to visit Das-T's homepage.
LAB3
posted March 12, 2011 02:12 PM
Is your battery fully charged? Remove the battery cables and clean them, check the battery for a full charge and correct voltage. Then read your owners manual and try to re-set the digital clock..
If this does not work look at the ground for the gauge cluster.Or a loose connection to the gauges.
Das-T
posted March 13, 2011 01:21 AM
Thanks ....LAB3 ...as soon I`m back home I will check that....Still in Angola for two weeks....
Das-T
0.37090587615967 seconds processing time
