BIKELAND > FORUMS > ZX-14.com > Thread: What fairing pad is this? NEW TOPIC NEW POLL POST REPLY
Rook
posted March 07, 2011 03:41 PM        Edited By: Rook on 7 Mar 2011 23:45
Mines an 08 and i have never seen this dohicky before. Have a buddy with an 06 and he is stumped on where this foam pad came from other than it fell out of a fairing. About 1" thick. Seems to be a little cooked and broken in half, maybe?
Sure looks like (half of) part marked #39156 ('06) on this fiche (just above center of diagram and it is surrounded by a fine black line).
1. Where did this foam piece come from?
2. How does it go back on (over which parts- any details would be helpful--not always obvious how those softish pads go back in the fairings.
3. Why is it only on the '06 and not later models?
3. Is this pad necessary or beneficial in any way? What does it do?
Thank you in advance fellas.
LeonidasZX14
posted March 07, 2011 03:44 PM
It came from the coolant resevoir
09' ZX14
Rook
posted March 07, 2011 03:50 PM
MMMMMMMM--that's what I thought at first, Leo but the coolant res pad has a rectangular openning where it adjoins the coolant bottle. Here is what 1" pads I have in my 08. Both on the left (clutch lever) side-- one in the lower on water pump and other on the coolant bottle.
I don't think the top photo is either of these pictured here. It really looks like diamond shaped one at center of the parts fiche------but I do not have that on my bike. Must be just on the 06?????????
LeonidasZX14
posted March 07, 2011 03:52 PM
Who knows then? I threw away all that stuff anyways.
09' ZX14
TH1RT3EN
Trial And Error Control
posted March 07, 2011 04:02 PM
Lower radiator hose just in front of the water pump if i remember correctly.
Ill go check in a min and see if i am right...
Patrick
kawasakijockey
posted March 07, 2011 04:21 PM
passenger side of bike at the rad hose by the the ignition pickup cover.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
1badzx12r
posted March 07, 2011 04:32 PM
give this man a cookie
kawasakijockey
posted March 07, 2011 04:39 PM
Duh! I said "passenger side of bike"....take the cookie back.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
Rook
posted March 07, 2011 04:52 PM
^^ I like that -have to remember that one---"passenger side of bike>" Good. Works for me. Lot less confusing than rear brake/sprocket side.
.........until you start talking to someone from outside of the US/Canada.
Rook
posted March 07, 2011 05:03 PM
I figured it out.
I have an 06 service manual and it shows this pad in one of the appendices.
BUT I STILL NEED HELP WITH MY 08!!!!!
How the heck many fairing pads should I have? I can only find 3. Two on the left (water pump and coolant reservoir) and one on the right radiator hose). Am I missing any?
1badzx12r
posted March 07, 2011 05:11 PM
that be why you got a cookie instead of a cracker you cracker ..
bradkong12
posted March 07, 2011 06:26 PM
last pic top left???? just got mine back together , then found the 1 n pic
it must hav fell out
Wheres it go? havnt lookd yet , if i hav 2 take fairing off, it will stay n box till next winter lol
2008 SE
bradkong12
bradkong12
posted March 07, 2011 06:28 PM
see it now on 06 service man u post, yeap its stayn n box
bradkong12
Ratfink
posted March 07, 2011 06:53 PM
i took all mine out i figured it was extra weight that i didnt need
Rook
posted March 07, 2011 09:31 PM
2008 SE
To clarify, the top pad in the pic with squared hole goes over coolant reservoir.
The top pad in pic with round hole goes on the large radiator hose (covered with braided plastic material)on throttle control/front brake lever side of bike.
The bottom pad in pic goes on water pump.
Should I have any other of these pads on an 08? Am I missing any?
posted March 08, 2011 02:47 AM
What you need to do is take your fairings off and throw all that shit away. Then you can worry about important stuff on the bike.
Rook
posted March 08, 2011 05:48 AM
I'm slowly but surely taking off rubber mats and a few other odds and ends. Can't bear to do anything that can't easily and inexpensively be reversed. After this year, I'm doing what I want to do. An 08 with 35K miles will not be worth more than a few grand anyway. Resale won'y be much a part of the equation any longer.
Seems to be confirmed that above pic shows all 3 foam chunks that are removable from fairings and sides of bike. All other foam is stuck on.
Rook
posted March 08, 2011 05:49 AM
Thanks for all replies, guys.
0.22654509544373 seconds processing time
