BIKELAND > FORUMS > ZX-14.com > Thread: suggestions on running 6.00s in a 1/8 NEW TOPIC NEW POLL POST REPLY
bradkong12
posted March 06, 2011 03:53 PM
cheapest way 2 get n the 6.00s in a 1/8 mile , 08 SE last year runs 6.32s ,best run 6.95, 60foots 1.65s , stock no powercommander or exhaust , she is lowered and strapd, roaring toys ext running around 6in over, stock gearing .
Will pulln flies powercommander and a exhaust get me n 6.00s or different gears???
Thinkn about muzzy M10 M14 , would love a alien head, but poor man lol
Need 2 go cheap, suggestions ????
my weight 150
THKS GUYS
bradkong12
LeonidasZX14
posted March 06, 2011 04:21 PM
Seat time man, with your mods and weight you should run 6.00s all day long. Work on your 60ft times. Just to give you a goal shoot for 1.450s and that should get you right there.
09' ZX14
posted March 06, 2011 04:21 PM        Edited By: eklipse636 on 7 Mar 2011 00:25
With you being a lightweight, there shouldn't be any problem. Looks like it's all in your 60ft,but you need to get that 60ft down to at least consistant 1.4's. Try putting a 16t front sprocket on. That will make it a lot easier to launch and only set you back about $35
Quarter Pounder
with Cheese
posted March 06, 2011 04:54 PM        Edited By: Quarter Pounder on 7 Mar 2011 00:56
You need to learn how to 60' the bike better. Being extended, you should be down in the 1.5s easy. I pull 1.5s on SWB so you should be pulling low 1.5s and you'll be where you want to be.
Also regear that thing....drop on tooth up front for now and see what that does for you. Make one change at a time to see what it does and learn what it takes to be quick. Seat time seat time seat time seat time
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
posted March 06, 2011 05:14 PM
With seat time, you can do 6.0 60foots stock wheelbase, especially at 150lbs...
Bently
2012 14r In Blue and no Mods!
posted March 06, 2011 06:27 PM
Yup seat time, run the shit out of that bike. at 150 lbs 5.90s should be easy at 6 inches over. at 6 inches over you should go 1.45 to 1.50 60 fts. which would get you right there. IMO untill you can 60 ft like that your throwing money away doing mods.
bradkong12
posted March 07, 2011 12:07 PM
THKS dudes , helpd alot , wasnt sure if 6.00s were possible , with set up , going down a gear 4 sure , my 60foots must suck balls
Thinkn im not getn WOT fast enough
Any throttle suggestions what r u dudes running
bradkong12
almost_les
posted March 07, 2011 12:18 PM
i've seen a lot of new guys at the track work backward for getting good launches. don't worry about raising rpms, focus on getting aggressive with the throttle. even an aggressive launch at 3500 will be smoother and quicker than revving to 7 , tossing the clutch way too fast, bogging the motor, and then finally rolling on.
i know its a 600, but the theory is the same, here is the WRONG way to do it:
sure, the first ten feet were fast, but then all the momentum was lost.
remember, smooth is fast
posted March 07, 2011 01:23 PM        Edited By: smokinZX14 on 7 Mar 2011 21:23
my weight 150
THKS GUYS
Do a little reading here > http://www.bikeland.org/board/viewthread.php?FID=27&TID=58165&set_time=
posted March 07, 2011 02:32 PM
im by far the bes here, but i have a few videos on youtube where i was messing around with my helmet camera. it shows my hands and rpm's
search "eklipse636" on youtube
posted March 07, 2011 02:42 PM        Edited By: Shane661 on 7 Mar 2011 22:42
At your weight, wheelbase, and with a pipe...you will run 5.90's with ease as long you get your 60 foots to 1.50 or better. As has been mentioned, get that throttle open quickly...before the 60' mark...and the clutch out as close to the 60' (or sooner) as you can.. Let that motor do the work.
CraigChrist
BAWLS
posted March 07, 2011 02:43 PM
lol, nice dusty. Why don't you pat your own back a little . "I'm by far the best here". You're good, but we all know that IMFASTOO is the best lol
60ft-------1.42
1/8th------5.97
mph-------119
posted March 07, 2011 03:43 PM
I was just trying to help the guy out. Bawls, did you ever run in the 5's more than once on your stretched bike?
bradkong12
posted March 07, 2011 04:54 PM
Video wrong way!!!
WHAT TIPD U OFF??? jj lmao
Think he was drunk or tryn 2 mouse trap
thks dudes it all helps thks again
bradkong12
bradkong12
posted March 07, 2011 04:59 PM
best run was 6.295 not 6.95 lol, sounds like 60foots r killn me, getn sprocket first thing
bradkong12
TH1RT3EN
Trial And Error Control
posted March 07, 2011 05:04 PM
I had a good pointer from eklipse636 last season.
I took a WOT switch and hooked it up to a led strip i put under my dash. When i hit WOT it lights up. Pretty freakin bright too. The led strip is set to where it will illuminate everything under the gauges and bars so it wont blind me. I am not getting to WOT as quick as i think i am so this is just a little help to make sure i get there.
Just an idea if you want to know if your getting to WOT as fast as you think you are. I know i was surprised.
Patrick
bradkong12
posted March 07, 2011 05:05 PM
hey smoke, which thread u talkn about?
it wouldn't let me use link idk
bradkong12
TH1RT3EN
posted March 07, 2011 05:11 PM
Assist: http://www.bikeland.org/board/viewthread.php?FID=27&TID=58165&set_time=
Drag racing 101 , It's at the top of the page ..
bradkong12
posted March 07, 2011 05:29 PM
gotcha , will read
TH1RT3EN u from IN , im southern IN , 20miles from louisville,KY
if so where u running?? only track iv ran is ohiovalley bs 1/8 mile and can only get about 6 runs a nite
bradkong12
CraigChrist
BAWLS
posted March 07, 2011 07:02 PM
lol dusty sure did... and can just about guarantee that you would have problems getting into the 5's in our air out here... Fatty Mcfatterson. BTW, I ran 5's on my second time ever on a stretched bike. and only got to take it to the track 3 times with it stretched then had to deploy again. How long did it take you to get where you are?
P.s. Don't make me come to georgia and fight you because my new job is probably going to have me in jacksonville quite a bit next year.
60ft-------1.42
1/8th------5.97
mph-------119
posted March 08, 2011 02:50 AM
Then you will have no excuses to run in the 5's.
(I might be a little on the heavy side, but I still outran you by .3
TH1RT3EN
posted March 08, 2011 07:29 AM
gotcha , will read
Yeah im from Indy,
I run out at O'reilly Raceway Park on tuesdays when i can get off of work. I usually get to make at least 8-10 passes a night. the most i have made in one night was 27.
Track is not too bad, it is a NHRA sanctioned 1/4 mile track. if you run faster then 9.99 you have to be licenced.
I will be hitting up Muncie Dragway a few times this year hopefully. It is not sanctioned so the licence doesnt matter.
http://www.munciedragway.com/
http://www.lucasoilraceway.com/apcm/templates/racedivisions.asp?articleid=17809&zoneid=95
O'reilly has now been changed to "Lucas Oil Raceway" and the street legal days have been moved to Wednesday's. Looks like opening day is 3-30-11.
Patrick
bradkong12
posted March 08, 2011 01:51 PM
TH1RT3EN gotcha im 90miles south of indy, i used 2 go 2 IRP every year 4 superchevy
How much does it cost 2 run on tuesdays???? and can u licence then??
Bunch of us rode up last year and hungout at the circle downtown . Must hav been 200bikes thr
The ride back at 2am not much fun after putn 300miles on her that day
bradkong12
posted March 12, 2011 06:14 AM        Edited By: CrotchRocket on 12 Mar 2011 14:17
went to Jason Miller's StreetBike Seminar yesterday.....
Ran a 6.07, 6.05, 6.03......
The bike, 2008 14, lowered, Brock alien, NO Name-baseline map, Power1 tire with 38lbs., pump gas, 40tooth rear sprocket, oem air filter, catalyst seat, foot shifting, fly's in.....stock wheel base!!!
Not bad for a 175lb. without leathers, fat guy huh...lol, as compared to the 130-150lb. jockeys out there.....
For us heavier guys, remember you need to launch at a higher RPM to pull the extra weight.....
The Clutch Technique is called " The SNAP n SLIDE " .....Learn it, Live it, Love it.....
0.23182916641235 seconds processing time
