BIKELAND > FORUMS > ZX-14.com > Thread: Track map vs. street map NEW TOPIC NEW POLL POST REPLY
kawasakijockey
posted January 25, 2011 05:46 PM
Are any of you guys gaining any mph with the track map compared to the street map when using pump gas? I havent used the track map in a couple of years and forgot what exactly the reason was.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
CraigChrist
BAWLS
posted January 25, 2011 07:19 PM
my bike 60fted better on the track map, but i don't remember it mphing any better.
60ft-------1.42
1/8th------5.97
mph-------119
ninjaboy311
posted January 25, 2011 07:47 PM
I would run the track map in the winter and the street map in the summer. The track map seemed a little sluggish in the extreme heat, but ripped in the winter! Street map was leaner and made it better in the heat. Didn't really gain any MPH unless I would use race fuel (MR9).
Quarter Pounder
with Cheese
posted January 26, 2011 06:22 AM
Thought the track map was set up for racing fuel while street map was set up for pump gas. Dunno, try it and see what the difference is.
James, you going to Pine Valley any time soon (if they are still open that is)?
SWB 2008 ZX-14
9.19 @ 151
5.98 @ 123
1.53 60'
posted January 26, 2011 06:47 AM
BPP-ZX14-06-Smeg-B-U_TRACK-NOSEC_MAP1.djm
2006 Kawasaki ZX14 (from BPP-ZX14-SmegBaffle-NO-TPLATES_TLmap1BESTDYNO)
**TRACK MAP for use in 2006 ZX-14 Power Commander 244-411**
Brock's Performance Street Megaphone with Baffle INSTALLED.
Secondary throttle plates REMOVED. (No TRE)
VP Fuels: MR9 ,U4 or MRXO1- 87-93 Octane Pump ok for street use.
Stock Engine with air cleaner removed for race track use. Filter cover MUST be in place to seal airbox after filter removal! Dyno may read low with this map.
Good weather with normal humidity. Works well in Hot/Humid conditions also.
Do not drive on street with filter removed!
Edgecrusher
posted January 26, 2011 07:57 AM
lol I think I'm too OCD to remove a filter completely even for track use. It'd worry me to death. I suck lol
kawasakijockey
posted January 26, 2011 09:15 AM
Jon, I went this past Sat and will more than likely try to go this Sat if I dont work.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
CajunBoyz
posted January 26, 2011 09:34 AM
On A side Note, Congradulation Pat, Another jockey(Jaxon) added to your stable
ninjaboy311
posted January 26, 2011 03:09 PM
Thanks!!!
gilberjj
Friend of Fast
posted January 26, 2011 03:59 PM
I could never mph on the track map like I could with the street map....... however, now that I think about it, when I tried the track map, I was missing one of the air box well nuts.... hmmm.......
0.24616813659668 seconds processing time
