BIKELAND > FORUMS > ZX-14.com > Thread: pilot power slipping? HELP! NEW TOPIC NEW POLL POST REPLY
speedyme
posted January 11, 2011 06:07 PM
i've always had metzler m3 on my zx14 with no problems my chicken strips were litterally one eight of inch wide, then i found a really good deal on the pilot powers. i have 700 miles on them and when i lean over very far on the usual roads i ride, i can feel the rear slipping really bad , this is very discouraging, should i go up in pressure or down? i ve never had A problem like this, my front dosent seem to slip. i have 34 psi in front, and 38 rear. any help would be great, my chicken strips are a half inch!! ( i m not imaging it i can feel them slip) thanks
speedy
  Ignore this member    Click here to visit speedyme's homepage.
posted January 11, 2011 06:09 PM
scuff them in all over before pushing it hard on the sides. i run 42 psi.
speedyme
posted January 11, 2011 06:13 PM
i take it you have pilot powers? and they don't slip at 42psi ? how about the front? psi? so should i just slowly lean over a little bit by little bit to scuff them? i sure never had to on metzlers, this will probally be my only set of pilot powers, thanks for you help.
speedy
INTIMIDA2OR
RED rider!
posted January 12, 2011 01:15 AM
Regular pilot powers don't offer a whole lot of stick unlesst they're really hot. Pilot power 2cts are a different animal and are what should be used instead .
'06 Passion Red ZX-14
*Lee*
Superman T
posted January 12, 2011 05:18 AM
+1 if you want maximum stickyness
Vertigo99
posted January 12, 2011 06:11 AM
I wasn't aware that Pilot Powers came any other way than 2CT. Had my 2CT's for a year and love love love em. Supreme confidence with this rubber.
08 Atomic Silver
INTIMIDA2OR
RED rider!
posted January 12, 2011 07:33 AM
Yes you have to watch out when you buy tires. If the price is too cheap then it's probably the standard pilot power. Gotta look at the label for that 2ct lettering!
*Lee*
Cutback
posted January 12, 2011 07:38 AM
Unless you are a big guy, lower your rear tire pressure 2-4 lbs.
old enough to know better!
speedyme
posted January 12, 2011 07:45 AM
okay i will go down to 35 and try that i weigh 190 with equipment on , thanks just didnt know whether to go up or down in psi thanks alot
speedy
Cutback
posted January 12, 2011 07:55 AM
FWIW, I run 36f/34r sport touring, 34f/32r aggressive, no strips, 175lbs, full gear
68gts2
hobbies ( Beating you !!! )
posted January 13, 2011 08:42 AM
I have the 2ct's and think they are awsome. That being said the guys at STG say unless your riding a track day you will never notice a difference. I'm running 36 front and 34 rear psi. We have the Dragon and Blue Ridge Parkway on them as well as the Baby Dragon in Dover Tn.also Land Between The Lakes across the street and have neve felt a slip with these tires. You need less air in the rear because it handles more load and generates more heat.cold to hot psi can be almost 6psi which puts you at around 44psi which I suspect is the reason your getting bad feedback from your tires. Hope it helps.
0.21589589118958 seconds processing time
