BIKELAND > FORUMS > ZX-14.com > Thread: No more cam chain noise NEW TOPIC NEW POLL POST REPLY
Flame On
Fuel Air & Spark
posted January 07, 2011 01:17 PM
I have not heard my cam chain at start up for some time now. I use to hear it all the time at start up for about a half minute then it would go away. I think the Shell rotela T6 oil I have switch to must of have silenced it. And I spead shift all the time daily riding very smooth. I was a little concernd about the cheaper oil but has done well in my 14 with 57K.
77 RD 400
80 GS1000 GT
06 ZX14
dakota9498
posted January 07, 2011 02:17 PM
or maybe its a coincidence because I use that same oil and i still get the noise, but I know its just part of it and it doesn't really bother me
2008 ZX14
zxbob
posted January 07, 2011 04:27 PM
Bob
zx14fan
posted January 07, 2011 05:04 PM
The oil has nothing to do with that noise.Its the oil pressure that stops the noise not the oil.
MotoCycho
posted January 07, 2011 05:15 PM        Edited By: MotoCycho on 8 Jan 2011 01:20
Maybe the tensioner clicked out to the next notch. It is spring loaded to some degree and auto adjusts as your cam chain stretches. It is basically on a ratcheting mechanism that doesn't allow the tensioner to be any looser than the maximum stretch just before the next step on the ratchet. Therefore your chain can only ever be that lose. Once it clicks out to next step the chain will be tighter again until it stretches a bit. When the gap is smaller oil may not run out due to surface tension or the oil pressure takes up the slack faster when its close and there is much less noise. Either way, it is only temporary. Trust me, your cam chain noise is coming back. It
Rook
posted January 07, 2011 05:31 PM
Just a thought--I'm not a synthetic user. Tried Repsol 4-T Race once. No CCT noise for a couple hundred miles. By 500, it was like normal oil. Might try a dif brand some day but the Repsol wasn't worth it AFAIC.
posted January 07, 2011 06:31 PM
I've used rotella, amsoil, maxium, and I still get the rattle. I think it's a coincidence.
Rook, not to start another oil thread, but it's been proven over that synthetic is the way to go.
Rook
posted January 07, 2011 08:54 PM
Oh--why not- this is an oil thread already.
Yeah--I'll try it again. A different brand of synthetic, definitely. I'm putting an APE CCT on there soon so I believe that noise will be silenced forever. It's not even that bad but for $50, seems kind of fun.
I will say, the shifting was extremely slick with the Repsol I used 2 years ago but it lasted very briefly and then all was normal.. I don't want to pay $70 for normal. Yeah, Rotela can be purchased at Walmart for cheap, I know. I'm just apprehensive about using an oil that is not motorcyce specific. I know---everybody uses Rotela and there are no problems.
blackbullet76
posted January 07, 2011 11:13 PM
The APE tensioner was the fix for my rattle at start-up.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
gilberjj
Friend of Fast
posted January 08, 2011 12:13 AM
My fix was just plugging my ears at startup....
Has there ever been a cct failure or is it just a an OCD issue?
gilberjj
Friend of Fast
posted January 08, 2011 12:15 AM
Rotella syn t6 is now JASMO certified now..... just so you know....
posted January 08, 2011 02:28 AM
Damn. It's not just hd truck oil anymore.
A lot of guys here use mobil1 as well. No problems.
Togive you a good example, my bike has mostly has rotella. I changed the clutch in November, thinking after 1 1/2 years and approx 400 dragstrip passes it's got to be close to being gone. Nope. Clutch still looks good.
indynic
Lil Show, Lil Go
posted January 08, 2011 06:42 AM
The APE Manual is the way to go IMHO!
kawpower
Mr kawasaki 2 you!
posted January 08, 2011 07:30 AM
The MODDED ZX12R tensioner is the real fixxer hands down!!!!!!!!!!!!
Nelson Taylor
posted January 08, 2011 07:40 AM
kawpower, who does this mod and is installation just like the APE CCT tensior?
Best #'s
1.54
4.03
6.02 @ 121mph
(Stock Wheelbase) 2006 ZX14
indynic
Lil Show, Lil Go
posted January 08, 2011 08:26 AM
Not sure if the install is as easy as the APE, but it cost almost three times as much because the factory zx12r tensioner is like $100. Then, you have to get it modified.
The automatic adjusters (like the zx12r's) can back out at high rpm when you let off the gas which could lead to top end damage.
What I like about the APE is that it is easy to install and set. It is SO easy to adjust and does not need adjusting very often at all. (Not even every oil change for me) Also, it maintains constant pressure on the cam chain no matter what the rpm or throttle position.
I think you would be good to go either way APE or modded zx12r CCT, but I would say get rid of that stock CCT, it gets embarrassing everytime you start your bike. People look at you like "what the f**k's wrong with your bike?"
kawpower
Mr kawasaki 2 you!
posted January 08, 2011 08:51 AM
u take the zx12r cct a machine shop have them cut 125thou off the seat install the way u would on the 12r on the 14 ur done, or u can buy from bob carpenter for 125dollars already done,far as backin out, ive run the ape 1/2 season broke a chain and ruined a head, ran and still run the 12r cct for 3 seasons on my nos 14 with ape hd springs and have had nooo problems with well over 2000 hard passes. ape cct needs attention frequently the 12r mod none.
indynic
Lil Show, Lil Go
posted January 08, 2011 02:22 PM
Sounds like there are some variables there.....Was your cam chain already worn out? How tight were you setting the manual CCT.
Rook
posted January 08, 2011 02:39 PM
Read quite a number of posts in the past few weeks and this is the first owner I have heard that reported a problem with the APE CCT. Haven't heard anyone complain about a modded ZX-12 CCT.
indynic
Lil Show, Lil Go
posted January 08, 2011 03:18 PM
Yeah, like I said, APE Manual or zx12r CCT, I think either way you'd be alright.
Big_T112
posted January 08, 2011 07:48 PM
I can't tell you how many burnt up cam chain guides I have repaired in the past from a manual tensioner improperly tightened. Other than that you can't beat it. I would use the 12R modded one on mine but the turbo 14 had a APE manual.
Nelson Taylor
posted January 08, 2011 08:16 PM
Thanks guys for the responses and input guys.
Best #'s
1.54
4.03
6.02 @ 121mph
LAB3
posted January 09, 2011 11:56 AM
Jim at Comp CNC did the machine work on my ZX-12 CCT. If you do not have the "Touch" a manual CCT will cause you problems in the long run. I have tried several different brands of oil with no help on cold start CCT tick. Modded ZX-12 is my pick.
posted January 11, 2011 06:30 PM
i run motul 300v and love it. bike dyno's like new after over 4 years of riding.
INTIMIDA2OR
RED rider!
posted January 11, 2011 06:59 PM
Oil thread , oil thread , oil thread!!!
'06 Passion Red ZX-14
*Lee*
0.2258198261261 seconds processing time
