BIKELAND > FORUMS > ZX-14.com > Thread: turbosmart wastegate NEW TOPIC NEW POLL POST REPLY
750 turbo
posted January 03, 2011 03:32 PM
Any one install a 38mm turbosmart wasgate on there zx14? What did you use for a boost controller?
Big_T112
posted January 03, 2011 05:02 PM
Cheap, not as good as some of the others on the market, Good if you are not going to make a lot of boost, diaphram prone to fail from airshifter backfires. MSBC-1, Boostbysmith, AMS-500, AMS-1000, Several people have made them. You can also do the cheap bleeder valve on the signal hose to fool the wastgate by bleeding off air for your second stage. Aquarium Fish tank bleeder valves work good to for manual control. Adjust them on the fly.
0.22420501708984 seconds processing time
