BIKELAND > FORUMS > ZX-14.com > Thread: FI light comes on under boost NEW TOPIC NEW POLL POST REPLY
Meangreen14
posted December 06, 2010 02:54 PM
whats up guys, any one have problems with FI sign sowing on on ur dash under boost, it comes on high RPM around 8500rpm in sixth air/fuel is reading ok...
PCV, quick shifter, stock gearing,
fly's out, custom garrett gt28 stage1 turbo, JE pistons, 625cc inj, MTC lock up clutch,1:1 fuel pressure regulator...
gilberjj
Friend of Fast
posted December 06, 2010 03:10 PM
You have the one way valve installed and working correctly in front of the map sensor?
01smokes
posted December 06, 2010 03:48 PM
injectors are maxed out up the fuel pressure
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
Meangreen14
posted December 06, 2010 04:13 PM
Ok cool I'll check valve and up the fuel pressure a Lil more
01smokes
posted December 06, 2010 05:54 PM
how much boost are you on are you on stock injectors??? and what is the static fuel pressure at?
Meangreen14
posted December 06, 2010 06:49 PM
5lb boost creeps to 6.5-7, yes still on stock injectors and pressure is at 65
01smokes
posted December 06, 2010 09:22 PM
what year is your bike, you need to run a FMU for stock injectors...
NINJA12
posted December 06, 2010 09:48 PM
it's probably the check valve.The map sensor throws a light with very little boost pressure.
It should never see boost.
I like to run the check off a T with it in the end vented to air
You would be surprised at how much the map sensor controls the mapping.
01smokes
posted December 06, 2010 09:50 PM
ive never had a check valve on my bike ever and it always seamed to run fine. ill put one in this time around
NINJA12
posted December 06, 2010 10:42 PM
have you always made boost?
did you just seal a leak? My bike trip the light with a 4 lb spring in it.
I'm no pro this is my first turbo and i'm learning as i go.
01smokes
posted December 06, 2010 10:49 PM
my FI light came on once on 12psi i just gave it a few more psi of fuel and that took care of it
Meangreen14
posted December 07, 2010 08:51 AM
Bike is a 2009
gilberjj
Friend of Fast
posted December 07, 2010 12:17 PM
Could it be because you have an external map sensor hooked up to your multi function hub?
NINJA12
posted December 07, 2010 01:48 PM
i don't understand why that would work.
We dont have a closed loop system. you bike would not know it was lean to throw a code.
And the duty cycle on the injectors would be the same with more fuel pressure. just richer.
zxbob
posted December 08, 2010 04:58 AM
Winner !
Bob
0.27581691741943 seconds processing time
