BIKELAND > FORUMS > ZX-14.com > Thread: Shane661: 14 Forks and Brakes to 12R? NEW TOPIC NEW POLL POST REPLY
WARBIRD
posted December 01, 2010 03:59 PM
Can I put 14 forks and brakes on my 12? I searched and got conflicting opinions....... sure would like to make the change over if possible.
I'd Rather Be Roadracing.
posted December 01, 2010 04:52 PM
14 Wheels, yes. Rear brake with minimal time and effort. Otherwise, I haven't tried the forks and front brakes. Rear wheel is a direct swap, although 12R has a smaller rotor. Front brake spacing is narrower on the 14, although axle and wheel spacing is almost identical....if not identical.
00Busa
Trying to go FASTER !
posted December 01, 2010 05:00 PM
I've got a set of forks and brakes if you need them.
'00 Busa / '06 14 /
IT AINT BRAGGING, IF YOU CAN BACK IT UP !
posted December 01, 2010 06:03 PM
just wondering what advantage there is to this, is the 14 stuff lighter?
WARBIRD
posted December 01, 2010 06:21 PM
Hey Steve,
The radial mount calipers rotors and master cyl. are far superior to the 12's. That why the change........but it appears it may not be feasible.
WARBIRD
posted December 01, 2010 06:24 PM
O.K. Shane, thanks for the quick reply. That's kind af a bummer........
00Busa.........thanks but I have already found the parts..........now if I could just use them.
posted December 01, 2010 06:31 PM
Hey Steve,
thanks for the info
oldkawboy
posted December 01, 2010 08:22 PM
What all ya got Charles? I've been flirting with putting a better front end and brakes on my turbo ZRX.
Gotta have a winter project!
Dan
WARBIRD
posted December 02, 2010 06:34 AM
Hi Dan,
I found a brand new set of 0 miles 08 14 forks, calipers, brake hoses, master cyl and brake lever. I think the upper and lower clamps, stem and bearings are available also. If this is too much of a project for my 12 ( it appears that way at the moment ) then I will go with Ohlins front and rear, BST's and Brembo stuff. I thought this route might be more economical, but it seems that is not so. I will let you know something right away.
P.S. This is my winter project......along with your Akra exhaust system and a 1270 kit. I bought this 12 new in 2000, it has 2001 miles on it and is "pristine". It never sat on the showroom floor............
Charles
CraigChrist
BAWLS
posted December 02, 2010 06:51 AM
2001 miles on a 2000 model? cheesus christ lol. Get off the computer and ride your freakin' bike lol.
60ft-------1.42
1/8th------5.97
mph-------119
WARBIRD
posted December 02, 2010 07:53 AM
lol........... I do get out and ride Craig. I just ride some of the other bikes more than this 12. I bought 2 of them and a Hayabusa in 2000...........sold the "Busa"............ I ride the 14 more than anything else.
posted December 02, 2010 01:54 PM        Edited By: dubious on 2 Dec 2010 21:54
I put a zx14 front end on Vmax, Imsure going to a zx12 would be easier.
The stems might need to be swapped but i bet otherwise a direct bolt on.
I know the zx10 and zx14 will swap over stem and all. same bearings even.
fork length and clip on clearance were the only issues
WARBIRD
posted December 02, 2010 03:05 PM
Thank's Lyle..............)
0.22859787940979 seconds processing time
