BIKELAND > FORUMS > ZX-14.com > Thread: WEGO III Install ?'s NEW TOPIC NEW POLL POST REPLY
Wheelie
Old Man
posted November 15, 2010 07:44 AM
just ordered my Wego III, who has installed one? Where and what wires do I tap into?
wee
quick6
posted November 15, 2010 09:06 AM
i have a dj wideband. it was simple to hook up. just 12v power, ground, find the wire on your tps that gives a varible voltage(0-4.9v) that will go to your tps wire on the wego, rpm neg. side of number 1 coil. and that should be about it. great tool btw.
2006 zx14, fully dressed and sliding(Charlie Sheen)
06redzx14
posted November 15, 2010 09:10 AM
Grab the y/white tracer at ecu this is tps 0-5 signal voltage. If your standing behind the bike it will be on the left side of the ecu 9th pin on bottom row on big connecter. WHITE/RED tracer top row 1st pin on little connecter from right is #1 coil grag rpm signal,both of these are on the ecu thats under the tool box come back aleast 3inches from connecter as not to pull against the poles when you reconnect
zx-14lvr
posted November 15, 2010 03:42 PM
whats this?
Lucky14
posted November 15, 2010 08:19 PM
Wee! Go!
Wheelie
Old Man
posted November 18, 2010 07:40 PM
Wee Go installed, but I cant install the software on either computers, vista and xp.
wee
Lucky14
posted November 18, 2010 08:38 PM
Maybe the CD is bad?
Download the latest software here:
http://www.daytona-sensors.com/tech_download.html
They also have notes about how-to on Vista and Windows 7.
AcadianaZX
Advertiser
posted November 18, 2010 11:04 PM
wee
Hey Wee, Did you have to purchase the wego tach adapter also?
James
Wheelie
Old Man
posted November 19, 2010 04:05 AM
wee
James
didn't get the tach adapter, online software didn't work either.
wee
LeonidasZX14
posted November 19, 2010 05:28 AM
Is it ok to tap the WEGO and a progressive controller into that same wire?
09' ZX14
06redzx14
posted November 19, 2010 06:09 AM
yes mine is wired that way
BIKELAND > FORUMS > ZX-14.com > Thread: WEGO III Install ?\'s NEW TOPIC NEW POLL POST REPLY
0.22479009628296 seconds processing time
