BIKELAND > FORUMS > ZX-14.com > Thread: finaly getting the turbo bike running again!!! NEW TOPIC NEW POLL POST REPLY
01smokes
posted October 24, 2010 08:29 AM
well i picked up a stock 06 motor with wiring harness and ecu with a PC3 for 1500 bucks ill be putting springs in this motor while its out of the bike, is there anything else you guys think i should do to it before i put it?
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
posted October 24, 2010 09:59 AM
well lots, depends whats your budget
Big_T112
posted October 24, 2010 01:37 PM
HD APE cylinder studs, I would pull the counterbalace shafts and put dummy shafts in it. Get a high pressure oil pressure relief valve from Schnitz Racing. Me, I would put new rod bearings in it for good measure in case the previous owner was a squid who liked to hold the bike on the rev limiter in neutral because he thought it looked and sounded cool.
LAB3
posted October 24, 2010 04:03 PM
Good idea.........are you going back on the Boost or spray?
TurboBike
posted October 24, 2010 07:11 PM        Edited By: TurboBike on 25 Oct 2010 03:14
just to be an ass.....
Post title states "finaly getting the turbo bike running again!!!"
But you never know.....Art changes his mind on a daily basis....reminds me of someone I know... LOL!!
RACE WHAT YOU BRUNG AND HOPE YOU BRUNG ENUFF
1badzx12r
posted October 24, 2010 07:36 PM
if your gonna do all that .may as well thermal coat the pistons .
i don't like the APE studs because i've heard you can't remove the head with the motor in frame .. i didn't see no studs in gadsen's bike in his thread on head porting
zx14fan
posted October 24, 2010 09:54 PM
If the motor is out of the bike then I guess you will be putting it in the bike hmm??
LAB3
posted October 25, 2010 04:14 AM
Good point......but I bet his race bike engine gets new bearings etc several times a season.
For street bike that has a owner that can't leave the boost alone :-) hardened studs is good move. Now send me my jelly donut....... Bogart.
Big_T112
posted October 25, 2010 07:13 AM
You can put rod bearings in it and all the other stuff without removing the pistons if you want.
INTIMIDA2OR
RED rider!
posted October 26, 2010 02:00 PM
" finaly getting the turbo bike running again!!!"
Sweet!
'06 Passion Red ZX-14
*Lee*
fq a busa
posted October 26, 2010 08:37 PM
fixing to put a stage 1 mr.turbo kit on my 07 zx14 u guys have any GOOD advice on what needs to be done ie...valve springs,clutch springs etc...???
GOT BOOST???
01smokes
posted October 26, 2010 08:56 PM
good fuel system, and a wideband to check AFRs a good safe tune, put springs on the clutch valve springs are good for 6-8psi but would be better if you put em in its just cheap insurance its 300 bucks and a few hours of time rather than thousands re building a bike
fq a busa
posted October 27, 2010 06:45 AM
sweet barnetts clutch springs should work then? any suggestions on da valve springs? ape?and do any of you know the diff.between the turbonetics,and the garrett turbos n general?
GOT BOOST???
johnbull
posted October 27, 2010 08:02 AM
Kibblewhite have the valves, valve springs, retainers, billet buckets - everything you could ever need.
For your build I would just go for the springs and retainers and you should be fine.
Re. fuelling, it depends on what boost you plan on running - stock pump is good for 280/300BHP.
Re. injectors - my advise would be to go for bigger injectors and therefore retaining stock fuel pressure and NOT using an FMU because in my opinion it is a FALSE solution to the problem and injectors dont like working at the high pressure that an FMU would produce!!
John Bul Racing. Malta.
0.2403130531311 seconds processing time
