BIKELAND > FORUMS > ZX-14.com > Thread: Throttle Tube Mod? NEW TOPIC NEW POLL POST REPLY
TH1RT3EN
Trial And Error Control
posted October 21, 2010 02:15 PM
Throttle Tube Mod?
Has anyone ever tried to see if an R1 throttle tube will fit on the zx14? I am seeing that the R1 tube is 1/6th of a turn. The zx14 is a 1/4 turn correct? I am just thinking it would be easier to get to WOT with less movement if the mod is possible.
Any Input??
Patrick
TH1RT3EN
posted October 21, 2010 02:21 PM
And yes i have already read this thread...
http://www.bikeland.org/board/viewthread.php?FID=27&TID=36246&pagenumber=3
I am just curious on who has all done this mod and if anyone has done the R1 or R6 tube as well....
Patrick
1badzx12r
posted October 21, 2010 02:21 PM        Edited By: 1badzx12r on 21 Oct 2010 22:24
yes there some guy that makes this mod for a zx14 .. but i forgot his name or website .. but he was or is a yamahaha goober
Compton
posted October 21, 2010 02:22 PM
i have the r1 tube on my bike.
b.w.
TH1RT3EN
posted October 21, 2010 03:56 PM
What do you think about it? Easy install? Worth the work?
What are your pro's & cons?
Patrick
06redzx14
posted October 21, 2010 05:32 PM
I had the r1 tube, but switched to the rifleman insert because it was less of a turn. Pita on the highway though
68gts2
hobbies ( Beating you !!! )
posted October 22, 2010 05:00 AM
Patrick how would you like a free set of grips with a quick twist throttle tube? Look up Avongrips.com, their grips come with a throttle tube that has changable cams. One of the cams is for the Yamaha 1/5th throttle. It is a bolt in for the 14,and the whole package is less than $20 for the base kit. If you want billet bar ends its about $60.
zx13r
Capt-America
posted October 22, 2010 05:45 AM
The r1 looked the same as the stock zx14 one. I couldn't see a difference...so I also did the rifleman mod!
Sposored By:
Kawasaki Sports Center
ShoTime Graphics.com
TH1RT3EN
posted October 22, 2010 09:56 AM
Thanks Peyton, I am checking it out now...
Patrick
Newf14
2007 ZX1400
posted October 24, 2010 05:06 AM
I e mailed him yesterday and now have a Rifleman Tube mod on the way, cant waite to get it gonna have lots of time to install it soon as winter sets in......
Newf14
Rifleman_duce
Yeah, that's what she said
posted October 24, 2010 12:00 PM
Guys, hope I can help and not voilate any board rules at the same time.
Yes, I make an insert for the 14R that fits inside the OEM housing and will give you a true 1/5th throttle (72' rotation between Idle and WOT)
Yes the R1 tube works, but it is not quite a full 1/5th, more like 77 or 78 degrees and it is also shorter then the the 14R tube so you get a gap between your bar end and the throttle tube... that and the rubber on the R1 will not match your 14R
this mod will retain OEM / Factory look and parts. It will reduce your throw from 91' OEM to 72. It is reversable. It has been performed on hundreds of 10R's and a few 14's with out problem.
If you have specific questions feel free to post them here or Email me directly.
If you want more info about purchase, Email me directly Rifleman@hotmail.com
]Need to know how to install your Rifleman's 1/5th throttle insert? click me
For more info on a sticky grip (not enough cable slack) click me
  Ignore this member    Click here to visit Rifleman_duce's homepage.
Rifleman_duce
posted October 24, 2010 12:08 PM
well, just looked at the linked thread... and that says it all.
RCRandy
posted October 24, 2010 03:07 PM
I'm currently using a throttlemiester with the stock throttle. Will it work if I switch to the Rifleman?
TH1RT3EN
posted October 24, 2010 03:40 PM
Yes the rifleman insert will work even if you are using Throttlemiesters...
Patrick
masszx14
A mind beside itself!
posted October 24, 2010 03:57 PM
Just my $0.02 here:
the R1 tube is a 1/5 turn
the R6 tube is a 1/6 turn
I tried both of them on my track gsxr and found out that the R6 tube was the right one for me as the R1 wasn't big enough of a reduction in twist to wot.
With the 1/6 turn tube I'm capable to grab wot (or actually as much as I need) without having to readjust my wrist whatsoever, which also allows me even more relaxed grip and precision of application.
universal@mind
sakawboy
09,muzzy m10 pwr cmdr v,few ot
posted October 31, 2010 12:41 PM
Just installed the throttle insert after a cupple minutes of grinding,and went for a quick test ride.HOLY $@#% what a difference! Instant response.Havent felt anything like that since the Elsinore days,thanks Rifeman,the best bang for your buck.
sakawboy
0.3797299861908 seconds processing time
