gilberjj
Friend of Fast
posted October 20, 2010 10:45 AM
Wideband Commander 2
I should buy some stock in dynojet.... I'm a rolling showcase for their products already, and I'll probably be getting their wideband commander as well. So, I just got off the phone with them, and they told me I could log all of the following...
a/f ratio
throttle position
injector duty cycle
boost pressure (because I have a multi function hub set up to map sensor)
rpm
all for about $350
wideband commander 2 with gauge: $289
harness to let them talk to each other: $50
Has anybody done this?
1badzx12r
posted October 20, 2010 12:36 PM
yes .. mine logs when it wants too.
gilberjj
Friend of Fast
posted October 20, 2010 02:49 PM
NEVERMIND!!!!! It ONLY works in conjunction with the pciii usb when you get the Wideband Commander, not the Wide Band Commander 2. This is confusing, but the Wide Band Commander 2 is a standalone unit that doesn't talk with the other dynojet products. What a crock of crap. This will run over $400.
Hellmutt
posted October 20, 2010 03:02 PM
Reality bites again - whats dynojet put 3 ounces of gold in every unit?
quick6
posted October 20, 2010 08:22 PM
in my opinion the original wideband commander is far better than the wideband2. the wideband2 you must have the lcd screen to do any logging of anykind. it doesnt have any software that im aware of so you can load it to a laptop to view it. the original wideband has internal memory and software where not only can you view your run, but export the data to a chart type file and view every sample it takes. i have the original on my 14 and a friend has the wb2 on his 14 and he wishes he bought the original.
2006 zx14, fully dressed and sliding(Charlie Sheen)
