BIKELAND > FORUMS > ZX-14.com > Thread: SMOKINZX14 NEW TOPIC NEW POLL POST REPLY
fury
posted October 14, 2010 01:17 AM
SMOKINZX14
You own or owned a dyno.
You did extensive test runs.
If I gave u the specs on my bike could you send maps?
I have been on a dyno. But the guy was a twit.
If I gave you the maps from my dyno run maybe you could look at them?
I would pay you for your services.
Thanks for your time.
I would need your email to send dyno generated map.
Let me know
posted October 14, 2010 02:04 AM
Every bike is different. He might get you close, but elevation, etc makes a difference
1badzx12r
posted October 14, 2010 06:49 AM
bullshitt ...1 map fit all ...... Brocks
posted October 14, 2010 09:27 AM
Let me know
The maps i have are Brocks ...Brock would kill me if i shared them ..His rules NOT mine .. I wish i could be of more help ... You might ask around and see if any will share a custom map or a Muzzy map .. But your best bet is to find a good tunner that can map it for you ..
JSmooth
posted October 21, 2010 11:31 AM
With that said are there any reputable tuners in KS area?
TH1RT3EN
Trial And Error Control
posted October 21, 2010 12:23 PM
What setup are you running? and version of a PC are you running?
I have a few maps from my old 07 with the PCIII. They were generated with a pipercross race filter, flies out and a Tsukigi full exhaust. I believe i have 2 different combo maps. and i believe i have the same type setup for a Busa. If they might work for you i could send them to you.
I have nothing but Brocks maps for the PCV and like smokin mentioned those are not leaving my possession either. (part of the agreement when i bought my system and got map support... Sorry)
Patrick
Swiftkart
posted October 21, 2010 01:55 PM
Simthers in KC
gilberjj
Friend of Fast
posted October 21, 2010 02:53 PM
What's your email, year of your bike and mods. I have collected a lot of maps over time, and I might have some that are close.
creeker
posted October 22, 2010 02:18 AM
A place in KCMO, WWW.CAFERACERINC.com
fury
posted December 30, 2010 06:57 AM
Thanks for the offers guys.
I am trying to find another chap with a dyno machine that knows what he is doing.
Someone that is not in a rush.
Happy New Years!
I love lock up clutches... 200kmh no juice.
More track time needed...
More tuning needed...
posted December 30, 2010 08:26 AM        Edited By: SteveWFL on 30 Dec 2010 16:26
if you just let smokin look at your bike it'll go faster with the map its got
08green
posted December 30, 2010 03:16 PM
Smokin I dont understand. If you made them on ur dyno with his pipe, does he own the maps too??
Just askin.
2004 ZX10
2008 ZX14
Rook
posted December 30, 2010 04:25 PM
^^^^semi educated guess on my part---Smokin' started with a Brock's map as a base and then dialed in off of that---perhaps largely a Brock's creation. That is integrity.
Would seem that a Brock's map would work at it's best with a Brock's system. That is half the reason I feel Brock's exhausts are among the best choices. The other half--they are race proven. Not cheap but the best and lightest. When you mod, think of it as a commitment. Spend the money to get what is best.
posted December 30, 2010 05:04 PM
Just askin.
I started with a Brocks map and made changes for the air we run in here in FL ..The changes are very small and made mostly to the very top of the Map.. The Map stays very much the way it comes from Brock... Lets say you have a brocks race map made in good air , Lets say 70s temps and 50% humidity ... Now we are running in 95 deg heat and 70+ % Humidity ... I would pull 3% or 3 numbers out of Brocks map at 100% throttle @ 9000 RPMs and UP to 11,000 RPMs .. That is not building a map , it's just touching it up a bit .. This adjustment may or may not make the bike faster , it might show more HP on the dyno but may not go faster at the track because the dyno has no ram air ... I will take that map to the track and test it against Brocks map , if i find no difference in ET and MPH i will discard that map and reinstall the Brocks Map .. If it does go faster i will save the map as Brocks Maps with notes to what changes i have made .. Either way it's still Brocks Map and he asked that they not be shared ..I'll tell you this , i have made many changes to Brocks Maps over the last 4 years and i always end up using his map the way he sent it to me ..In fact the very first Map he sent me in 2006 and used in my 2006 ZX14 is the very same map i use today in my 2009 ZX14 ..
dcjens
Wet side of Washington
posted December 30, 2010 07:07 PM
+1
Black 06
JSmooth
posted January 09, 2011 02:04 PM
Simthers in KC
do you have a number for him? It's winter time and i'm trying to get this bike ready by May any help I would appreciate it.
01smokes
posted January 09, 2011 04:51 PM
Canned maps are not always the way to go sometimes you Just need a Dyno tune.
PayPal, vigilart22@yahoo.com
Email, artvgl@yahoo.com
posted January 11, 2011 06:16 PM
brock's pipe and maps, you are done. i have been running them for 4 plus years with spot on performance.
0.30439114570618 seconds processing time
