BIKELAND > FORUMS > ZX-14.com > Thread: gear indicator wrong NEW TOPIC NEW POLL POST REPLY
06redzx14
posted September 19, 2010 11:03 AM
I'm currently using 16/44 gearing with 1 corner of the sprocket nut rounded. my gear indicator always seems to read 1 gear too low. last week i think I hit the speed restrictor (152) when the bike was in 6th gear, but the indicator read 5th. on the highway yesterday the bike would read 4th or 5th when cruising in 6th at 5K RPM. has anyone else ran into this? what's a possible fix? removed my healtech because it was making my bike surge
posted September 19, 2010 11:29 AM
It is a known issue. I don't understand why the ecu doesn't just use the output from the gear position sensor...it seems to look at rpm and speed for the display.
06redzx14
posted September 19, 2010 01:09 PM
what's the top speed on 16/44? I checked the gearing commander sight and it doesn't seem to be right. It says 153.5 in 6th gear. Would a tre that locks the indicator in 6th help?
posted September 19, 2010 04:14 PM
I don't think you hit the speed restrictor. I'm running 16/48 and I can do a actual 150 and not hit the restrictor.
06redzx14
posted September 19, 2010 06:32 PM
problem is my indicator never goes to 6th
1badzx12r
posted September 19, 2010 06:38 PM        Edited By: 1badzx12r on 20 Sep 2010 02:40
i didn't know 5th gear has a rev limit . except by running out of gearing in 5th
BobC
posted September 20, 2010 12:17 AM        Edited By: BobC on 20 Sep 2010 08:17
Top speed in 6th on 16/44 is 179mph at the engine rev limiter.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
68gts2
hobbies ( Beating you !!! )
posted September 21, 2010 12:36 PM
So if I grind the speed restrictor nut my gear indicator will read wrong when I'm done,damn. I hate the extra miles the speedo is getting with 17\43 and was fixing to do this mod,but now I don't know.
0.28462386131287 seconds processing time
