BIKELAND > FORUMS > ZX-14.com > Thread: Zx14 turbo issues NEW TOPIC NEW POLL POST REPLY
Meangreen14
posted September 18, 2010 05:53 PM
Zx14 turbo issues
Has any one ran across this problem, motor revs good up to 5,000rpm then it just falls on it's face and starts to jerk like it's tring to turn off, and wount go past 6 grand when ur riding it. Like it's not getting no gasoline? I checked fuel pressure it's at 70lb at idle and stays there while on the throttle?
PCV, quick shifter, stock gearing,
fly's out, custom garrett gt28 stage1 turbo, JE pistons, 625cc inj, MTC lock up clutch,1:1 fuel pressure regulator...
zxbob
posted September 18, 2010 05:59 PM
Change your plugs - they have a short life with a turbo !
Even if they look good, change em.
Should be 42 at idle and 70 to 80 on boost ..
Meangreen14
posted September 18, 2010 06:46 PM
I just changed the plugs still doing it. Smokinzx14 ok I'll lower it to 42 in the morning, so it rises while on boost?
gilberjj
Friend of Fast
posted September 18, 2010 07:01 PM
not yours! You need a rising rate fuel pressure regulator on stock injectors.
posted September 18, 2010 07:07 PM
His sig said " 1:1 rising rate fuel pressure regulator " Is that not a rising rate ?
Compton
posted September 19, 2010 02:02 AM
if he has a 1:1 aint no way he is going to see 72-80psi of pressure unless there is a lot of boost, lol
b.w.
Big_T112
posted September 19, 2010 05:10 AM
I used a B.E.G.I. 2025 and it was a 6 to 1. It cost about $250 and here is a link so you can read about it. You could be lean without if. At 8 to 10 pounds of boost we were seeing 80-90 lbs. of fuel with it.
http://www.racetep.com/begireg.html
1badzx12r
posted September 19, 2010 05:22 AM
ain't this the bike that was under water
Meangreen14
posted September 19, 2010 10:50 AM
Yes we got it all flushed changed plugs, fuel, oil.... But I have a fuel pressure Gage on the regulator and it is showing 70psi at idle! Maybe the power commander is not working properly? But every thing else works fine even the quick shifter that was completely under water over nite!
Meangreen14
posted September 19, 2010 10:52 AM
Also fuel pump is kinda loud compared to other turbo bikes I've seen, but at IDLE IT'S RUNNING 70pounds of pressure
Meangreen14
posted September 19, 2010 10:55 AM
Thanks Big_T112 I'll look into that
posted September 19, 2010 10:59 AM        Edited By: dubious on 19 Sep 2010 18:59
the regulator has a bleed port, so the diaphram can move, you might have water in the regulator.
That said, some turbo bikes with 1:1 regulator. and stock injectors have higher static fuel pressure to compensate for the small injectors as boost goes up.
check with the tuner if you dont know what the static should be.
boostphreak
posted September 19, 2010 11:31 AM
has the bike rver been tuned on a dyno? if you map is not fairly close its hard to suggest anyfhing. it almost sounds like a boost leak. also if its a cheap gauge you might check it against a new one
Big_T112
posted September 19, 2010 02:18 PM
Save yourself a lot of time and trouble and put the BEGI 2025 reg on it. set the static fuel pressure at stock then use the needle bleed valve to adjust on boost pressure. Start about 4 turns out. As boost rises you should see the fuel pressure increase. Very easy to tune and works really good plus off boost your bikes runs like normal.
posted September 19, 2010 05:25 PM
That or big injectors, and use the 1:1
all the pro's, adams, Jones, kizer, muzzy, NLR, RCC prefer a 1:1 regulator, but you need bigger injectors,
if you run a rising rate, begi as BigT says, has the best reputation.
Meangreen14
posted September 19, 2010 05:34 PM
You guys Know any good motorcycle Performance shops in central Texas?
posted September 19, 2010 05:36 PM
Johnnycheese , i think he is in Austin or close to Austin ..
Big_T112
posted September 19, 2010 06:41 PM
If you want it to be a really good streetbike use the one I told you about. On the ZX14 turbo kit I sold 01smokes on here we had the larger injectors, BEGI 2925 Reg and a Walboro FI pump.
Meangreen14
posted September 21, 2010 07:52 AM
I just unplugged the power commander and took it down the block to check if it was the power commander and it rode perfect with no hesitation so it's gatta be the PC rite?
Meangreen14
posted September 21, 2010 08:44 AM
I only ran it up to 8 grand slowly and shut down real quick on the street.
NINJA12
posted September 21, 2010 10:01 AM
reload your map and check it again.
Meangreen14
posted September 21, 2010 10:32 AM
Yeah it's wierd I reloaded map an reinstalled PC and it's doing it again, it's smooth all the way up to 5,500 RPMs then it starts to buck and hesitate so think PC is not working after 5,500 RPMs?
dakota9498
posted September 21, 2010 10:51 AM
Check you ground on the Power Commander, that is a common issue with those.
2008 ZX14
INTIMIDA2OR
RED rider!
posted September 21, 2010 09:23 PM
+1
'06 Passion Red ZX-14
*Lee*
0.21884393692017 seconds processing time
