BIKELAND > FORUMS > ZX-14.com > Thread: Lower Farring Bolts?? NEW TOPIC NEW POLL POST REPLY
TH1RT3EN
Trial And Error Control
posted September 09, 2010 10:24 AM        Edited By: TH1RT3EN on 9 Sep 2010 18:30
I have noticed that my 09 is becoming notorius for loseing the lower farring bolts just like my 07 was. I am thinking about using a drop of the Locktite Blue on each bolt that does not go into a well nut.
Has anyone else had this issue? If so what do you reccomend to use so you dont end up missing bolts often?
Patrick
nydhags
posted September 09, 2010 11:00 AM
I had the issue also, blue Loctite was my dealers solution, now I only lose them when i take the bike apart.
To Do List:
CONTINENTAL US DONE
Hawaii - I’ll rent a bike there, MAYBE
TH1RT3EN
posted September 09, 2010 05:37 PM
good deal, at least someone else was told what i was thinking. I have heard it both ways from dealers. Some say use blue locktite and some say dont.
ill give it a shot and see how well things work out.
Patrick
derpie
Dont judge a book by its cover
posted September 09, 2010 06:48 PM
+1 on the blue locktite , either that or buy a lot of spare bolts and parts.
MJ
posted September 10, 2010 12:58 AM
14's are notorious for losing those bolts. Everybody who's ever owned one that I've asked about has lost at least a couple including me, before they wised up and started using blue locktite on them. Now I put the blue on them every time I take them off/put them back on.
Vertigo99
posted September 10, 2010 05:25 AM
Lost mine a couple of times, and it usually takes the dealer a couple of tries to get the correct bolts from their supplier. I bought extras last time.
08 Atomic Silver
SLVR_BLT
Chicken Strips!
posted September 10, 2010 08:46 AM
Ive never had any come loose and they shouldn't either because the rubber portion on the back of the wellnuts gives the bolt a slight drag so it would prevent them from coming loose in the first place. Make sure you have the nylon washer in there as well.
TH1RT3EN
posted September 10, 2010 08:59 AM        Edited By: TH1RT3EN on 10 Sep 2010 17:01
i have never had any of the bolts come loose that are in well nuts. But the bolts i was referring to are located on the lower belly pan farring up front. there are 2 per side that come loose often if nothing is done to help them stay in (these bolts go into aluminum brackets, not well nuts). I have also noticed the front fender bolts like to loosen up over time as well...
Im going to hit the Non-Well Nut bolts with some Blue Locktite this weekend... Hopefully they stay put.
Patrick
zx14dreamin
posted September 10, 2010 09:37 AM
+1 I have lost mine as well. In fact that reminds me I need to take a look see if the replacments are still there.....
oilfieldtrash
Kawasaki enthusiast
posted September 10, 2010 09:38 AM
I had lost my lower fairing bolts. Went to autozone and found some matching bolts and just used them. 10mm bolt not allenhead though.
'07 white S.E. ZX-14 sold
posted September 11, 2010 04:12 PM
I've never had any problems with this on my 06 or 08...
Hellmutt
posted September 12, 2010 06:28 AM
I've got small rubberized washers at work that I use on ALL my bodypanel bolts -- never lost a single one.........biggest problem I have is rounding out the socket when I'm torqueing the caliper mounting bolts -- SHCS are the stupidest piece of hardware Kawasaki could've used on calipers -- I should replace those with Torx drive bolts instead, at least I'd be able to torque those down to the recommended spec without fear of rolling them out -- f*ckin' engineers....
LAB3
posted September 12, 2010 07:24 PM
I just checked mine.still tight.
0.24964904785156 seconds processing time
