BIKELAND > FORUMS > ZX-14.com > Thread: nitrous enable switch NEW TOPIC NEW POLL POST REPLY
wrongway
posted August 15, 2010 03:38 PM
I was replacing the PC3 with the PCv and autotune on the race bike. I was so pissed off at Loring when the datalogger quit working that I wanted a fail safe for the nitrous setup if I did not have logs and needed more nitrous
Since I was pulling out all of the wiring I had added to chase down the problem, I decided that I would use the 4 way flasher button to to enable te nitrous and the data logger. Now both controls are on the left hand control ( horn to turn on the nitorus , 4 way flasher to enable the system. All I had to do was replace the power wire from the flasher with a ground wire .I also cut the 2 wires going to the console that light the arrows but that isnt really necessary. I also removed the turn signal switch so the system could not accidentally be activated by hitting that.
It does look much cleaner now ( no extra wires or switches) , but this may not be a good idea if you still want to pass inspection:-)
Roy
shiphteey
posted August 15, 2010 04:37 PM
So Roy, how do you enable the flashers on the street to signify a decisive WIN against the other bike? A switch for the button?
Gemini Motorcycles
posted August 15, 2010 05:00 PM
I know a guy that used the 4way switch to activate his nitrous, then forgot to shut it off...Bike went boom, & on fire...
No Joke, its a true story!!!
wrongway
posted August 15, 2010 06:12 PM
i am using the 4-way to activate a solenoid that puts power to the rest of the circuits.. then the horn button grounds the nitous solenoid when I want to turn on the NOS.
Halvefast
posted August 16, 2010 09:12 AM
Just don't forget the WOT switch, mine has been wired to the hazards, works very well.
ECTA Ohio Mile 195.132mph
0.26636791229248 seconds processing time
